ERROR constant_mod.f:205
Error 1005: Unknown value for keyword UNITS: Please help meLigniteGasification.mfx (19.6 KB)
Was this file edited outside the GUI? Looks like it is missing the units keyword. Try manually adding units = 'si' to the .mfx file. 8.3.1. Run Control — MFiX 19.2.0 documentation
Yes this file C3M export and I changed the file name …dat to …mfx and open this file GUI and type other parameters. How can I add manually. ?
thanks but solid error
ERROR check_data\check_solids_continuum.f:42
Error 1000: Required input not specified: EP_STAR
Please correct the project settings.
ERROR check_data\check_solids_continuum.f:341
Error 1203: Angle of internal friction (PHI) not specified.
ERROR check_data\check_solids_continuum.f:128
Error 1101: Coefficient of restitution (C_E) not specified.
ERROR check_data\check_solids_continuum.f:135
Error 1102: Coefficient of friction (C_F) not specified.
Process exit C:\Users\musay\Anaconda3\envs\mfix-19.2.0\Scripts\mfixsolver.exe -s -f C:\Users\musay\Desktop\Reaktor\LigniteGasification\LigniteGasification
WARNING check_data\check_gas_phase.f:252
Message: 2000 The energy equations are being solved (ENERGY_EQ) and
the constant gas specific heat is undefined (C_PG0). Thus, the thermo-
chemical database will be used to gather specific heat data on the
individual gas phase species. simulation stopped.
Looks like C3M does not generate runnable project files as it is missing many keywords/ICs/etc. Did you mange to get this project running?
