I only changed the particle density in my case, then i got this error:
Error 1000: Unable to match particles crossing processor boundaries.
Source Proc: 0 —> Destination Proc: 0
Global Particle ID: 819
Does anyone have solutions for this error? thanks.
Can you post your case? How many processors are you running on and what compiler/version?
Two things to check:
- Are your particles too soft (KN too small)?
- If you are using an STL file for geometries, is it of good quality?
Both of these can result in particles moving too fast causing the MPI pack/unpack routines to fail.
Hi Onlyjus,
Only one processors I used, and I tried both intel and gfortran compiler. it is not the first time I got this error. I was thinking it is not directly related with processors. Anyway, thank you for your help.
Hi Jmusser,
Good idea, i will check kn and solid time step.Thank you.
