Hello
I receive this message when trying to save the project:
WARNING check_data\check_gas_phase.f:120
Message 2000: MW_AVG is not needed when solving species equations.
What can I do about it? because its not saved because of it.
Thanks
Hello
Thanks
That’s a run-time error coming from the “check_data” routine - that happens when starting a simulation. It shouldn’t be triggered when saving a project. And since it’s just a WARNING, it shouldn’t be stopping the project from being saved. Is it possible that you are having a different problem? How do you know the project is not being saved?
Thank you for your reply. I figured out that it didn’t stop the project from saving like you said. Thanks a lot.
