an error occured when setup the fluid material.
test_3_2022-04-11T153734.186275.zip (31.8 MB)
Thanks for the bug report. Can you tell me what you did right before this error happened? I’m not quite sure how to reproduce it.
i just double click the fluid material and the Warning window pops up.
This is odd. I cannot reproduce the error. The message above looks like there was no selected row in the species table. But if you double-click, the first click should have made a selection.
Does this happen every time or was it a one-time problem?
What happens if you select a species (single-click on a row) then use the ‘Edit’ (pencil) icon to modify it?
