Error occured while opening MFix
An error occurred while running MFiX. Please report this error at NETL Flow Science Software Support
If you continue running, the application may become unstable. Consider saving your work now.
Error: can only concatenate str (not “int”) to str
File “C:\Users\sroy27\AppData\Local\miniforge3\envs\mfix-24.4\Scripts\mfix-script.py”, line 9, in
sys.exit(main())
File “…\main.py”, line 24, in main
main_args(sys.argv[1:])
File “…\main.py”, line 232, in main_args
gui.open_project(project_file, interactive=(not args.test))
File “…\gui.py”, line 3157, in open_project
self.post_open(project_file, pidfile)
File “…\gui.py”, line 3487, in post_open
self.init_background_mesh()
File “…\mesh.py”, line 412, in init_background_mesh
self.extract_mesh_spacing(i, d)
File “…\mesh.py”, line 442, in extract_mesh_spacing
loc = count*val + start
Save diagnostic report?
How to fix this issue?
Can you please attach the files for the MFiX case you are trying to open?
Note that starting MFiX from the command line with “mfix -n” will keep it from opening the previous project. But you will still encounter this problem when you try to open the problematic project.
Mfix is working. I just need to update the mfix version in miniforge promt.
