Hi
As per the suggestion from mfix-gui, I would like to report this error
An error occurred while running MFiX. Please report this error at NETL Flow Science Software Support
If you continue running, the application may become unstable. Consider saving your work now.
Error: ‘NoneType’ object has no attribute ‘endswith’
File “/home/vkotteda/Software/anaconda3/envs/mfix-20.1/bin/mfix”, line 10, in
sys.exit(main())
File “…/gui.py”, line 3331, in main
main_args(sys.argv[1:])
File “…/gui.py”, line 3503, in main_args
gui.open_project(project_file, interactive=(not args.test))
File “…/gui.py”, line 2675, in open_project
self.do_open(project_file, pidfile)
File “…/gui.py”, line 3071, in do_open
self.change_mode(mode)
File “…/gui.py”, line 1655, in change_mode
self.set_solver(self.project.solver) # Reset titlebar & status message
File “…/model_setup.py”, line 198, in set_solver
self.bcs_set_default_keys(i)
File “…/bcs.py”, line 1250, in bcs_set_default_keys
if bc_type.endswith(‘W’):
Save diagnostic report?
sys.exit(main())
Opening in existing browser session.
[0904/090045.072709:ERROR:nacl_helper_linux.cc(308)] NaCl helper process running without a sandbox!
Most likely you need to configure your SUID sandbox correctly
Please see the attached bug report for more details:
tfm_2020-09-04T090719.036087.zip (32.9 KB)
Reinstalling the mfix-20.2 does not solve this problem. So, I
renamed the directory that contains the mfx file to get rid of this error.
Thank you
