Error of installation mfix-24
I had installed version 24.2.2, but after using it for a while there was an error that didn’t compile, so I removed it and removed the 24.2.2 environment. When I try to install version 24, the following error occurs.
(base) C:\Users\user>conda create -n mfix-24.4 mfix==24.4 mfix-doc==24.4 mfix-gui==24.4 mfix-solver==24.4 mfix-src==24.4 -c conda-forge -c https://mfix.netl.doe.gov/s3/09ed68c0/2644a66085a7d322e219baa045e43628//conda/dist
Collecting package metadata (current_repodata.json): done
Solving environment: failed with repodata from current_repodata.json, will retry with next repodata source.
Collecting package metadata (repodata.json): done
Solving environment: -
Found conflicts! Looking for incompatible packages.
This can take several minutes. Press CTRL-C to abort.
Examining mfix-gui==24.4: 67%|██████████████████████████████████████▋ | 4/6 [00:00<00:00, 22.65it/s]-failed
  File "C:\Anaconda3\lib\site-packages\conda\exceptions.py", line 1079, in __call__
    return func(*args, **kwargs)
  File "C:\Anaconda3\lib\site-packages\conda\cli\main.py", line 84, in _main
    exit_code = do_call(args, p)
  File "C:\Anaconda3\lib\site-packages\conda\cli\conda_argparse.py", line 82, in do_call
    return getattr(module, func_name)(args, parser)
  File "C:\Anaconda3\lib\site-packages\conda\cli\main_create.py", line 37, in execute
    install(args, parser, 'create')
  File "C:\Anaconda3\lib\site-packages\conda\cli\install.py", line 265, in install
    should_retry_solve=(_should_retry_unfrozen or repodata_fn != repodata_fns[-1]),
  File "C:\Anaconda3\lib\site-packages\conda\core\solve.py", line 117, in solve_for_transaction
    should_retry_solve)
  File "C:\Anaconda3\lib\site-packages\conda\core\solve.py", line 158, in solve_for_diff
    force_remove, should_retry_solve)
  File "C:\Anaconda3\lib\site-packages\conda\core\solve.py", line 281, in solve_final_state
    ssc = self._run_sat(ssc)
  File "C:\Anaconda3\lib\site-packages\conda\common\io.py", line 88, in decorated
    return f(*args, **kwds)
  File "C:\Anaconda3\lib\site-packages\conda\core\solve.py", line 808, in _run_sat
    should_retry_solve=ssc.should_retry_solve
  File "C:\Anaconda3\lib\site-packages\conda\resolve.py", line 1318, in solve
    self.find_conflicts(specs, specs_to_add, history_specs)
  File "C:\Anaconda3\lib\site-packages\conda\resolve.py", line 347, in find_conflicts
    bad_deps = self.build_conflict_map(specs, specs_to_add, history_specs)
  File "C:\Anaconda3\lib\site-packages\conda\resolve.py", line 507, in build_conflict_map
    root, search_node, dep_graph, num_occurances)
  File "C:\Anaconda3\lib\site-packages\conda\resolve.py", line 369, in breadth_first_search_for_dep_graph
    last_spec = MatchSpec.union((path[-1], target_paths[-1][-1]))[0]
  File "C:\Anaconda3\lib\site-packages\conda\models\match_spec.py", line 481, in union
    return cls.merge(match_specs, union=True)
  File "C:\Anaconda3\lib\site-packages\conda\models\match_spec.py", line 475, in merge
    reduce(lambda x, y: x._merge(y, union), group) if len(group) > 1 else group[0]
  File "C:\Anaconda3\lib\site-packages\conda\models\match_spec.py", line 475, in <lambda>
  File "C:\Anaconda3\lib\site-packages\conda\models\match_spec.py", line 502, in _merge
    final = this_component.union(that_component)
  File "C:\Anaconda3\lib\site-packages\conda\models\match_spec.py", line 764, in union
    return '|'.join(options)
TypeError: sequence item 0: expected str instance, Channel found
$ C:\Anaconda3\Scripts\conda-script.py create -n mfix-24.4 mfix==24.4 mfix-doc==24.4 mfix-gui==24.4 mfix-solver==24.4 mfix-src==24.4 -c conda-forge -c https://mfix.netl.doe.gov/s3/09ed68c0/2644a66085a7d322e219baa045e43628//conda/dist
environment variables:
CIO_TEST=
CONDA_DEFAULT_ENV=base
CONDA_EXE=C:\Anaconda3\condabin..\Scripts\conda.exe
CONDA_EXES=“C:\Anaconda3\condabin..\Scripts\conda.exe”
CONDA_PREFIX=C:\Anaconda3
CONDA_PROMPT_MODIFIER=(base)
CONDA_PYTHON_EXE=C:\Anaconda3\python.exe
CONDA_ROOT=C:\Anaconda3
CONDA_SHLVL=1
HOMEPATH=\Users\user
PATH=C:\Anaconda3;C:\Anaconda3\Library\mingw-w64\bin;C:\Anaconda3\Library\u
sr\bin;C:\Anaconda3\Library\bin;C:\Anaconda3\Scripts;C:\Anaconda3\bin;
C:\Anaconda3\condabin;D:\Tecplot2018\Tecplot Chorus 2018
R1\bin;D:\Tecplot2018\Tecplot 360 EX 2018 R1\bin;C:\Program
Files\Microsoft MPI\Bin;C:\ProgramData\Oracle\Java\javapath;C:\WINDOWS
\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\Wind
owsPowerShell\v1.0;C:\WINDOWS\System32\OpenSSH;C:\Program
Files\dotnet;C:\Program Files\PuTTY;D:\MATLAB2020a\runtime\win64;D:\MA
TLAB2020a\bin;D:\MATLAB2020a\polyspace\bin;C:\Users\user\AppData\Local
\Microsoft\WindowsApps;D:\SciTools\bin\pc-win64;D:\REFPROP
PSMODULEPATH=C:\Program Files\WindowsPowerShell\Modules;C:\WINDOWS\system32\Windows
PowerShell\v1.0\Modules
REQUESTS_CA_BUNDLE=
SSL_CERT_FILE=
 active environment : base
active env location : C:\Anaconda3
        shell level : 1
   user config file : C:\Users\user\.condarc
populated config files : C:\Users\user.condarc
conda version : 4.8.2
conda-build version : 3.18.11
python version : 3.7.6.final.0
virtual packages : __cuda=11.7
base environment : C:\Anaconda3 (writable)
channel URLs : conda-forge/win-64
conda-forge/noarch
https://mfix.netl.doe.gov/s3/09ed68c0/2644a66085a7d322e219baa045e43628//conda/dist/win-64
https://mfix.netl.doe.gov/s3/09ed68c0/2644a66085a7d322e219baa045e43628//conda/dist/noarch
main/win-64
main/noarch
r/win-64
r/noarch
msys2/win-64
msys2/noarch
package cache : C:\Anaconda3\pkgs
C:\Users\user.conda\pkgs
C:\Users\user\AppData\Local\conda\conda\pkgs
envs directories : C:\Anaconda3\envs
C:\Users\user.conda\envs
C:\Users\user\AppData\Local\conda\conda\envs
platform : win-64
user-agent : conda/4.8.2 requests/2.22.0 CPython/3.7.6 Windows/10 Windows/10.0.19041
administrator : False
netrc file : None
offline mode : False
If submitted, this report will be used by core maintainers to improve
future releases of conda.
Would you like conda to send this report to the core maintainers?
Upload did not complete.
Thank you for helping to improve conda.
Opt-in to always sending reports (and not see this message again)
by running
$ conda config --set report_errors true
I’m not sure how to fix this problem but we have observed that sometimes the mamba command succeeds where conda fails. (mamba is a rewritten version of the Conda installer)
