Please select the most relevant MFiX category: Bug report.
Hi, Developers
I met this error when i try to opening mfix 23.2,but when i try to change the version to mfix 21.1.4,mfix 20.1.2,i can open mifx success.
I try to update the version of numpy,,iBut I still can’t open it.
ImportError: DLL load failed while importing _mt19937
OS version:win11
cgw
July 17, 2023, 8:57pm
2
I’ve never seen this error before. Can you please go to the main menu, select “Submit bug report” and upload the ZIP file?
When I tried to open it(MFix23.2), the image (I attached it below) flashed and then these error prompts appeared.
cgw
July 18, 2023, 4:39pm
9
Can you please run (with the mfix-23.2 environment activated) these three commands, and copy/paste the output here:
(mfix-23.2) mfixversioninfo
(mfix-23.2) conda info
(mfix-23.2) conda list
Thanks!
cgw
July 20, 2023, 1:26pm
11
This thread has gotten confusing, as there are now two separate errors under discussion.
@PoorWesley posted about an error on Windows, ‘DLL Load failed’. Then @MFIX_LYP added a comment about an unrelated problem on CentOS 7. Please don’t do this! - it creates confusion and extra work for us who are doing support.
@MFiX_LYP Please start a new topic, with a relevant subject line.
@PoorWesley if you are still reading this can you please do:
and paste the results here? Thanks.
Hi ,I am sorry for not giving you a prompt reply due to the busy work in recently.
The result after I input these codes is as follows:
(mfix-23.2) PS C:\Users\lywl1> mfixversioninfo
MFiX: 23.2
Python: 3.10.12 | packaged by conda-forge | (main, Jun 23 2023, 22:34:57) [MSC v.1936 64 bit (AMD64)]
gfortran: GNU Fortran (Rev5, Built by MSYS2 project) 5.3.0
openmpi: Unavailable
Qt wrapper: PyQt5
Qt: 5.15.6
qtpy: 2.3.1
numpy: Unavailable
nodeworks: Unavailable
flask: 2.3.2
psutil: 5.9.5
VTK: 9.2.6
OpenGL backend: 2
System info: Windows-10-10.0.22621-SP0
Install location: D:\Anaconda3\envs\mfix-23.2\share\mfix
Default solver: D:\Anaconda3\envs\mfix-23.2\Scripts\mfixsolver.exe
Solver source: D:\Anaconda3\envs\mfix-23.2\share\mfix\src
(mfix-23.2) PS C:\Users\lywl1> conda info
active environment : mfix-23.2
active env location : D:\Anaconda3\envs\mfix-23.2
shell level : 2
user config file : C:\Users\lywl1\.condarc
populated config files : C:\Users\lywl1\.condarc
conda version : 4.12.0
conda-build version : 3.21.8
python version : 3.9.12.final.0
virtual packages : __win=0=0
__archspec=1=x86_64
base environment : D:\Anaconda3 (read only)
conda av data dir : D:\Anaconda3\etc\conda
conda av metadata url : None
channel URLs : https://repo.anaconda.com/pkgs/main/win-64
https://repo.anaconda.com/pkgs/main/noarch
https://repo.anaconda.com/pkgs/r/win-64
https://repo.anaconda.com/pkgs/r/noarch
https://repo.anaconda.com/pkgs/msys2/win-64
https://repo.anaconda.com/pkgs/msys2/noarch
package cache : D:\Anaconda3\pkgs
C:\Users\lywl1\.conda\pkgs
C:\Users\lywl1\AppData\Local\conda\conda\pkgs
envs directories : D:\Anaconda3\envs
D:\Anaconda\envs
C:\Users\lywl1\.conda\envs
C:\Users\lywl1\AppData\Local\conda\conda\envs
platform : win-64
user-agent : conda/4.12.0 requests/2.27.1 CPython/3.9.12 Windows/10 Windows/10.0.22621
administrator : False
netrc file : None
offline mode : False
(mfix-23.2) PS C:\Users\lywl1> conda list
# packages in environment at D:\Anaconda3\envs\mfix-23.2:
# Name Version Build Channel
aiohttp 3.8.5 py310h8d17308_0 conda-forge
aiosignal 1.3.1 pyhd8ed1ab_0 conda-forge
aom 3.5.0 h63175ca_0 conda-forge
async-timeout 4.0.2 pyhd8ed1ab_0 conda-forge
attrs 23.1.0 pyh71513ae_1 conda-forge
blinker 1.6.2 pyhd8ed1ab_0 conda-forge
blosc 1.21.4 hdccc3a2_0 conda-forge
brotli 1.0.9 hcfcfb64_9 conda-forge
brotli-bin 1.0.9 hcfcfb64_9 conda-forge
brotli-python 1.0.9 py310h00ffb61_9 conda-forge
bzip2 1.0.8 h8ffe710_4 conda-forge
ca-certificates 2023.5.7 h56e8100_0 conda-forge
certifi 2023.5.7 pyhd8ed1ab_0 conda-forge
charset-normalizer 3.2.0 pyhd8ed1ab_0 conda-forge
click 8.1.6 win_pyh7428d3b_0 conda-forge
cmake 3.26.4 h1537add_0 conda-forge
colorama 0.4.6 pyhd8ed1ab_0 conda-forge
contourpy 1.1.0 py310h232114e_0 conda-forge
cycler 0.11.0 pyhd8ed1ab_0 conda-forge
dav1d 1.2.1 hcfcfb64_0 conda-forge
double-conversion 3.3.0 h63175ca_0 conda-forge
eigen 3.4.1 h91493d7_0 conda-forge
expat 2.5.0 h63175ca_1 conda-forge
ffmpeg 6.0.0 gpl_h2b371f0_103 conda-forge
ffmpeg-python 0.2.0 py_0 conda-forge
flask 2.3.2 pyhd8ed1ab_0 conda-forge
font-ttf-dejavu-sans-mono 2.37 hab24e00_0 conda-forge
font-ttf-inconsolata 3.000 h77eed37_0 conda-forge
font-ttf-source-code-pro 2.038 h77eed37_0 conda-forge
font-ttf-ubuntu 0.83 hab24e00_0 conda-forge
fontconfig 2.14.2 hbde0cde_0 conda-forge
fonts-conda-ecosystem 1 0 conda-forge
fonts-conda-forge 1 0 conda-forge
fonttools 4.41.1 py310h8d17308_0 conda-forge
freetype 2.12.1 h546665d_1 conda-forge
frozenlist 1.4.0 py310h8d17308_0 conda-forge
future 0.18.3 pyhd8ed1ab_0 conda-forge
gettext 0.21.1 h5728263_0 conda-forge
git 2.41.0 h57928b3_0 conda-forge
gitdb 4.0.10 pyhd8ed1ab_0 conda-forge
gitpython 3.1.32 pyhd8ed1ab_0 conda-forge
gl2ps 1.4.2 h0597ee9_0 conda-forge
glew 2.1.0 h39d44d4_2 conda-forge
glib 2.76.4 h12be248_0 conda-forge
glib-tools 2.76.4 h12be248_0 conda-forge
gst-plugins-base 1.22.5 h001b923_0 conda-forge
gstreamer 1.22.5 hb4038d2_0 conda-forge
hdf4 4.2.15 h1334946_6 conda-forge
hdf5 1.14.1 nompi_h73e8ff5_100 conda-forge
icu 72.1 h63175ca_0 conda-forge
idna 3.4 pyhd8ed1ab_0 conda-forge
importlib-metadata 6.8.0 pyha770c72_0 conda-forge
intel-openmp 2023.1.0 h57928b3_46319 conda-forge
itsdangerous 2.1.2 pyhd8ed1ab_0 conda-forge
jinja2 3.1.2 pyhd8ed1ab_1 conda-forge
jsoncpp 1.9.5 h2d74725_1 conda-forge
kiwisolver 1.4.4 py310h232114e_1 conda-forge
krb5 1.20.1 heb0366b_0 conda-forge
lcms2 2.15 h3e3b177_1 conda-forge
lerc 4.0.0 h63175ca_0 conda-forge
libaec 1.0.6 h63175ca_1 conda-forge
libblas 3.9.0 17_win64_mkl conda-forge
libbrotlicommon 1.0.9 hcfcfb64_9 conda-forge
libbrotlidec 1.0.9 hcfcfb64_9 conda-forge
libbrotlienc 1.0.9 hcfcfb64_9 conda-forge
libcblas 3.9.0 17_win64_mkl conda-forge
libclang 16.0.6 default_heb8d277_0 conda-forge
libclang13 16.0.6 default_hc80b9e7_0 conda-forge
libcurl 8.1.2 h68f0423_0 conda-forge
libdeflate 1.18 hcfcfb64_0 conda-forge
libexpat 2.5.0 h63175ca_1 conda-forge
libffi 3.4.2 h8ffe710_5 conda-forge
libglib 2.76.4 he8f3873_0 conda-forge
libhwloc 2.9.1 nocuda_h15da153_6 conda-forge
libiconv 1.17 h8ffe710_0 conda-forge
libjpeg-turbo 2.1.5.1 hcfcfb64_0 conda-forge
liblapack 3.9.0 17_win64_mkl conda-forge
libnetcdf 4.9.2 nompi_h5902ca5_107 conda-forge
libogg 1.3.4 h8ffe710_1 conda-forge
libopus 1.3.1 h8ffe710_1 conda-forge
libpng 1.6.39 h19919ed_0 conda-forge
libpython 2.2 py310h5588dad_2 conda-forge
libsqlite 3.42.0 hcfcfb64_0 conda-forge
libssh2 1.11.0 h7dfc565_0 conda-forge
libtheora 1.1.1 h8d14728_1005 conda-forge
libtiff 4.5.1 h6c8260b_0 conda-forge
libvorbis 1.3.7 h0e60522_0 conda-forge
libwebp-base 1.3.1 hcfcfb64_0 conda-forge
libxcb 1.15 hcd874cb_0 conda-forge
libxml2 2.11.4 hc3477c8_0 conda-forge
libzip 1.9.2 h519de47_1 conda-forge
libzlib 1.2.13 hcfcfb64_5 conda-forge
loguru 0.7.0 py310h5588dad_0 conda-forge
lz4-c 1.9.4 hcfcfb64_0 conda-forge
m2w64-binutils 2.25.1 5 conda-forge
m2w64-bzip2 1.0.6 6 conda-forge
m2w64-crt-git 5.0.0.4636.2595836 2 conda-forge
m2w64-gcc 5.3.0 6 conda-forge
m2w64-gcc-ada 5.3.0 6 conda-forge
m2w64-gcc-fortran 5.3.0 6 conda-forge
m2w64-gcc-libgfortran 5.3.0 6 conda-forge
m2w64-gcc-libs 5.3.0 7 conda-forge
m2w64-gcc-libs-core 5.3.0 7 conda-forge
m2w64-gcc-objc 5.3.0 6 conda-forge
m2w64-gmp 6.1.0 2 conda-forge
m2w64-headers-git 5.0.0.4636.c0ad18a 2 conda-forge
m2w64-isl 0.16.1 2 conda-forge
m2w64-libiconv 1.14 6 conda-forge
m2w64-libmangle-git 5.0.0.4509.2e5a9a2 2 conda-forge
m2w64-libwinpthread-git 5.0.0.4634.697f757 2 conda-forge
m2w64-make 4.1.2351.a80a8b8 2 conda-forge
m2w64-mpc 1.0.3 3 conda-forge
m2w64-mpfr 3.1.4 4 conda-forge
m2w64-pkg-config 0.29.1 2 conda-forge
m2w64-toolchain 5.3.0 7 conda-forge
m2w64-tools-git 5.0.0.4592.90b8472 2 conda-forge
m2w64-windows-default-manifest 6.4 3 conda-forge
m2w64-winpthreads-git 5.0.0.4634.697f757 2 conda-forge
m2w64-zlib 1.2.8 10 conda-forge
markupsafe 2.1.3 py310h8d17308_0 conda-forge
matplotlib 3.7.2 py310h5588dad_0 conda-forge
matplotlib-base 3.7.2 py310h51140c5_0 conda-forge
mfix 23.2 0 https://mfix.netl.doe.gov/s3/907de298/92a11979cbcec6d64f03c0f0ef0217bd//conda/dist
mfix-doc 23.2 0 https://mfix.netl.doe.gov/s3/907de298/92a11979cbcec6d64f03c0f0ef0217bd//conda/dist
mfix-gui 23.2 py_0 https://mfix.netl.doe.gov/s3/907de298/92a11979cbcec6d64f03c0f0ef0217bd//conda/dist
mfix-solver 23.2 py310_0 https://mfix.netl.doe.gov/s3/907de298/92a11979cbcec6d64f03c0f0ef0217bd//conda/dist
mfix-src 23.2 0 https://mfix.netl.doe.gov/s3/907de298/92a11979cbcec6d64f03c0f0ef0217bd//conda/dist
mkl 2022.1.0 h6a75c08_874 conda-forge
mscorefonts 0.0.1 3 conda-forge
msys2-conda-epoch 20160418 1 conda-forge
multidict 6.0.4 py310h8d17308_0 conda-forge
munkres 1.1.4 pyh9f0ad1d_0 conda-forge
nlohmann_json 3.11.2 h39d44d4_0 conda-forge
numpy 1.25.1 py310hd02465a_0 conda-forge
openh264 2.3.1 h63175ca_2 conda-forge
openjpeg 2.5.0 ha2aaf27_2 conda-forge
openssl 3.1.1 hcfcfb64_1 conda-forge
packaging 23.1 pyhd8ed1ab_0 conda-forge
pcre2 10.40 h17e33f8_0 conda-forge
pillow 10.0.0 py310hb653ca7_0 conda-forge
pip 23.2 pyhd8ed1ab_0 conda-forge
ply 3.11 py_1 conda-forge
proj 9.2.1 h660b3b0_0 conda-forge
psutil 5.9.5 py310h8d17308_0 conda-forge
pthread-stubs 0.4 hcd874cb_1001 conda-forge
pthreads-win32 2.9.1 hfa6e2cd_3 conda-forge
pugixml 1.13 h63175ca_1 conda-forge
pyparsing 3.0.9 pyhd8ed1ab_0 conda-forge
pyqt 5.15.7 py310h1fd54f2_3 conda-forge
pyqt5-sip 12.11.0 py310h00ffb61_3 conda-forge
pyqtgraph 0.13.3 pyhd8ed1ab_0 conda-forge
pysocks 1.7.1 pyh0701188_6 conda-forge
python 3.10.12 h4de0772_0_cpython conda-forge
python-dateutil 2.8.2 pyhd8ed1ab_0 conda-forge
python_abi 3.10 3_cp310 conda-forge
pyyaml 6.0 py310h8d17308_5 conda-forge
qt-main 5.15.8 h2c8576c_12 conda-forge
qtpy 2.3.1 pyhd8ed1ab_0 conda-forge
requests 2.31.0 pyhd8ed1ab_0 conda-forge
setuptools 68.0.0 pyhd8ed1ab_0 conda-forge
simplejson 3.19.1 py310h8d17308_0 conda-forge
sip 6.7.9 py310h00ffb61_0 conda-forge
six 1.16.0 pyh6c4a22f_0 conda-forge
smmap 3.0.5 pyh44b312d_0 conda-forge
snappy 1.1.10 hfb803bf_0 conda-forge
svt-av1 1.6.0 h63175ca_0 conda-forge
tbb 2021.9.0 h91493d7_0 conda-forge
tbb-devel 2021.9.0 h91493d7_0 conda-forge
tk 8.6.12 h8ffe710_0 conda-forge
toml 0.10.2 pyhd8ed1ab_0 conda-forge
tomli 2.0.1 pyhd8ed1ab_0 conda-forge
tornado 6.3.2 py310h8d17308_0 conda-forge
typing-extensions 4.7.1 hd8ed1ab_0 conda-forge
typing_extensions 4.7.1 pyha770c72_0 conda-forge
tzdata 2023c h71feb2d_0 conda-forge
ucrt 10.0.22621.0 h57928b3_0 conda-forge
unicodedata2 15.0.0 py310h8d17308_0 conda-forge
urllib3 2.0.4 pyhd8ed1ab_0 conda-forge
utfcpp 3.2.3 h57928b3_0 conda-forge
vc 14.3 h64f974e_17 conda-forge
vc14_runtime 14.36.32532 hfdfe4a8_17 conda-forge
vs2015_runtime 14.36.32532 h05e6639_17 conda-forge
vtk 9.2.6 qt_py310h1234567_208 conda-forge
vtk-base 9.2.6 qt_py310h1234567_208 conda-forge
werkzeug 2.3.6 pyhd8ed1ab_0 conda-forge
wheel 0.40.0 pyhd8ed1ab_1 conda-forge
win32_setctime 1.1.0 pyhd8ed1ab_0 conda-forge
win_inet_pton 1.1.0 pyhd8ed1ab_6 conda-forge
wslink 1.11.1 pyhd8ed1ab_0 conda-forge
x264 1!164.3095 h8ffe710_2 conda-forge
x265 3.5 h2d74725_3 conda-forge
xorg-libxau 1.0.11 hcd874cb_0 conda-forge
xorg-libxdmcp 1.1.3 hcd874cb_0 conda-forge
xz 5.2.6 h8d14728_0 conda-forge
yaml 0.2.5 h8ffe710_2 conda-forge
yarl 1.9.2 py310h8d17308_0 conda-forge
zipp 3.16.2 pyhd8ed1ab_0 conda-forge
zstd 1.5.2 h12be248_7 conda-forge
What I must tell you is that after I discovered the error, I switched the latest version of Anaconda to a lower version of Anaconda.
Thaks for your help.
cgw
July 23, 2023, 9:29pm
13
Can you try the alternative miniforge/mamba installation?
