Sharing a problem with a solution:
Version: 21.1.1 Built from tar.gz with pip
Python 3.9.7
When I would try to run a built solver, I would see this error (at the end of a long traceback)
ImportError: cannot import name ‘soft_unicode’ from ‘markupsafe’
This appears to be due to markupsafe removing or renaming soft_unicode. They recommend use of soft_str
It can be solved by rolling back your markupsafe to version 2.0.1, which still includes this class/function. You can do so by using this command:
pip install markupsafe==2.0.1
