Error running on centos7
Hello developers! I opened new project:silane_pyrolysis_pic_3d on centos7. The solver can be built smoothly. But if you run it on a single core, you will get FIG. 1 error. I tried the other cases and got the same error. When I use 4 cores, I get the error in Figure 2,3, where is the problem? Hope to get your help! By the way, I used version 23.1.
I can’t see what the problem is from the information provided.
Please attach all input files - go to main menu, “Submit bug report”, and attach the resulting ZIP file here. Thanks.
