I used mfix_dem to run a case with chemical reaction and, i used dmp to run the case .this error appears a lot .why and what should i do ? (for the dmp i=2 j=4 k=1 )
the model setup 5mm15mm1mm
Your chemical reactions/thermo is probably wrong. Make sure the rates make sense.
