Error when install Reason: Transfer finalized, status: 404
Can anyone help see what is causing the error reported during the MFiX installation below?
(base) C:\Users\Administrator>mamba create -n mfix-24.1.1 mfix==24.1.1 mfix-doc==24.1.1 mfix-gui==24.1.1 mfix-solver==24.1.1 mfix-src==24.1.1 -c conda-forge -c https://mfix.netl.doe.gov/s3/b349e728/1fbd86e0a6bd78834a8f5ae7794e2f1a//conda/dist
              __    __    __    __
/ / \ / \ / \ / \ ____
/ / _/ _/ _/ \ o _,
/ / _
__/ `
    mamba (1.4.2) supported by @QuantStack
    GitHub:  https://github.com/mamba-org/mamba
    Twitter: https://twitter.com/QuantStack
Looking for: [‘mfix==24.1.1’, ‘mfix-doc==24.1.1’, ‘mfix-gui==24.1.1’, ‘mfix-solver==24.1.1’, ‘mfix-src==24.1.1’]
anaconda/pkgs/main/win-64 404 failed 0.1s
conda-forge/win-64 404 failed 0.2s
conda-forge/noarch 404 failed 0.2s
Multi-download failed. Reason: Transfer finalized, status: 404 [http://mirrors.aliyun.com/anaconda/cloud/conda-forge/noarch/repodata.json] 2318 bytes
  File "C:\ProgramData\miniforge3\lib\site-packages\conda\exceptions.py", line 1132, in __call__
    return func(*args, **kwargs)
  File "C:\ProgramData\miniforge3\lib\site-packages\mamba\mamba.py", line 941, in exception_converter
    raise e
  File "C:\ProgramData\miniforge3\lib\site-packages\mamba\mamba.py", line 934, in exception_converter
    exit_code = _wrapped_main(*args, **kwargs)
  File "C:\ProgramData\miniforge3\lib\site-packages\mamba\mamba.py", line 892, in _wrapped_main
    result = do_call(parsed_args, p)
  File "C:\ProgramData\miniforge3\lib\site-packages\mamba\mamba.py", line 758, in do_call
    exit_code = create(args, parser)
  File "C:\ProgramData\miniforge3\lib\site-packages\mamba\mamba.py", line 632, in create
    return install(args, parser, "create")
  File "C:\ProgramData\miniforge3\lib\site-packages\mamba\mamba.py", line 499, in install
    index = load_channels(pool, channels, repos)
  File "C:\ProgramData\miniforge3\lib\site-packages\mamba\utils.py", line 129, in load_channels
    index = get_index(
  File "C:\ProgramData\miniforge3\lib\site-packages\mamba\utils.py", line 110, in get_index
    is_downloaded = dlist.download(api.MAMBA_DOWNLOAD_FAILFAST)
RuntimeError: Multi-download failed. Reason: Transfer finalized, status: 404 [http://mirrors.aliyun.com/anaconda/cloud/conda-forge/noarch/repodata.json] 2318 bytes
$ C:\ProgramData\miniforge3\Scripts\mamba create -n mfix-24.1.1 mfix==24.1.1 mfix-doc==24.1.1 mfix-gui==24.1.1 mfix-solver==24.1.1 mfix-src==24.1.1 -c conda-forge -c https://mfix.netl.doe.gov/s3/b349e728/1fbd86e0a6bd78834a8f5ae7794e2f1a//conda/dist
environment variables:
CIO_TEST=
CONDA_DEFAULT_ENV=base
CONDA_EXE=C:\ProgramData\miniforge3\condabin..\Scripts\conda.exe
CONDA_PREFIX=C:\ProgramData\miniforge3
CONDA_PROMPT_MODIFIER=(base)
CONDA_PYTHON_EXE=C:\ProgramData\miniforge3\python.exe
CONDA_ROOT=C:\ProgramData\miniforge3
CONDA_SHLVL=1
CURL_CA_BUNDLE=
HOMEPATH=\Users\Administrator
LD_PRELOAD=
PATH=C:\ProgramData\miniforge3;C:\ProgramData\miniforge3\Library\mingw-
w64\bin;C:\ProgramData\miniforge3\Library\usr\bin;C:\ProgramData\minif
orge3\Library\bin;C:\ProgramData\miniforge3\Scripts;C:\ProgramData\min
iforge3\bin;C:\ProgramData\miniforge3\condabin;C:\Software\vmware\bin;
C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\Sys
tem32\WindowsPowerShell\v1.0;C:\Program Files\dotnet;C:\Users\Administ
rator\AppData\Local\Microsoft\WindowsApps;.;C:\Software\Pycharm\2022.2
.5\bin;.
PSMODULEPATH=C:\Program Files\WindowsPowerShell\Modules;C:\Windows\system32\Windows
PowerShell\v1.0\Modules
REQUESTS_CA_BUNDLE=
SSL_CERT_FILE=
 active environment : base
active env location : C:\ProgramData\miniforge3
        shell level : 1
   user config file : C:\Users\Administrator\.condarc
populated config files : C:\ProgramData\miniforge3.condarc
C:\Users\Administrator.condarc
conda version : 23.3.1
conda-build version : not installed
python version : 3.10.12.final.0
virtual packages : __archspec=1=x86_64
__win=0=0
base environment : C:\ProgramData\miniforge3 (writable)
conda av data dir : C:\ProgramData\miniforge3\etc\conda
conda av metadata url : None
channel URLs : http://mirrors.aliyun.com/anaconda/cloud/conda-forge/win-64
https://mfix.netl.doe.gov/s3/b349e728/1fbd86e0a6bd78834a8f5ae7794e2f1a//conda/dist/win-64
https://mfix.netl.doe.gov/s3/b349e728/1fbd86e0a6bd78834a8f5ae7794e2f1a//conda/dist/noarch
http://mirrors.aliyun.com/anaconda/pkgs/main/win-64
http://mirrors.aliyun.com/anaconda/pkgs/main/noarch
http://mirrors.aliyun.com/anaconda/pkgs/r/win-64
http://mirrors.aliyun.com/anaconda/pkgs/r/noarch
http://mirrors.aliyun.com/anaconda/pkgs/msys2/win-64
http://mirrors.aliyun.com/anaconda/pkgs/msys2/noarch
package cache : C:\ProgramData\miniforge3\pkgs
C:\Users\Administrator.conda\pkgs
C:\Users\Administrator\AppData\Local\conda\conda\pkgs
envs directories : C:\ProgramData\miniforge3\envs
C:\Users\Administrator.conda\envs
C:\Users\Administrator\AppData\Local\conda\conda\envs
platform : win-64
user-agent : conda/23.3.1 requests/2.31.0 CPython/3.10.12 Windows/10 Windows/10.0.14393
administrator : True
netrc file : None
offline mode : False
404 error code means “Website not found”. The MFiX website may have been temporarily unreachable due to a network error. Please try again.
Thank you for your reply. The problem is that the conda-build was not installed. I installed the conda-build, the problem was solved.
conda-build is not necessary, I think it was just a transient network issue. I’m glad you got the installation to succeed.
I had the same problem on two different computers. So I looked up the MFiX installation issue in the forums and compared it with the conda info command and found the conda-build difference. I then tried to install conda-build, which completed and then installed MFiX successfully. This was the case for both computers. It is my personal experience.
This is very interesting!! Thanks for reporting. I think it is possible that it was just a coincidence (N=2 is not statistically overwhelming). Note that conda build is needed for building Conda packages (which we create for release to users) but not for building the solver (which is just a regular program, not a Conda package). conda build is not needed for installing Conda packages either. It’s hard to understand why lacking this package would cause a 404 error, which is much more likely due to network instability. Also, nobody else has ever reported needing conda build.
However, I don’t want to argue with your personal experience, and I’m glad you got MFiX installed successfully.
Good luck with MFiX, and please don’t hesitate to post if you have questions or problems.
