Hi Charles,
I attempted to remove anaconda and MFIX and found some other things. When I attempt to install gcc make on my cluster I get an error:
(mfix-20.1.2) [awinner3@n224 ~]$ conda install gcc make
Collecting package metadata (current_repodata.json): done
Solving environment: failed with initial frozen solve. Retrying with flexible solve.
Collecting package metadata (repodata.json): done
PackagesNotFoundError: The following packages are not available from current channels:
** - gcc**
Current channels:
** - https://repo.anaconda.com/pkgs/main/linux-64**
** - https://repo.anaconda.com/pkgs/main/noarch**
** - https://repo.anaconda.com/pkgs/r/linux-64**
** - https://repo.anaconda.com/pkgs/r/noarch**
To search for alternate channels that may provide the conda package you’re
looking for, navigate to
https://anaconda.org
and use the search bar at the top of the page.
I attempted to fix this issue by running:
conda install -c anaconda gcc make
but then if I try to launch MFIX, I get the following error:
(mfix-20.1.2) [awinner3@n224 ~]$ Traceback (most recent call last):
** File “/home/awinner3/anaconda3/envs/mfix-20.1.2/lib/python3.7/site-packages/qtpy/init.py”, line 204, in **
from PySide import version as PYSIDE_VERSION # analysis:ignore
ModuleNotFoundError: No module named 'PySide’
During handling of the above exception, another exception occurred:
** File “/home/awinner3/anaconda3/envs/mfix-20.1.2/bin/mfix”, line 6, in **
from mfixgui.gui import main
** File “/home/awinner3/anaconda3/envs/mfix-20.1.2/lib/python3.7/site-packages/mfixgui/gui.py”, line 27, in **
from qtpy import QtGui, QtCore, QtWidgets
** File “/home/awinner3/anaconda3/envs/mfix-20.1.2/lib/python3.7/site-packages/qtpy/init.py”, line 210, in **
raise PythonQtError(‘No Qt bindings could be found’)
qtpy.PythonQtError: No Qt bindings could be found
Not sure if the above is related to the previous issue or not. I also noticed I only get this run name error when trying to use the project solver. If I use the default solver, it doesn’t have an issue picking up the run name.
Best,
Amelia
