Error when use dem in linux
hello everyone,
I used mfix-23.1.1 in linux, when build the mfixsolver, it comes the error as below:
cmake --build . --target install -j 36
[ 0%] Building Fortran object model/CMakeFiles/mfixcore.dir/funits_mod.f.o
[ 1%] Building Fortran object model/CMakeFiles/mfixcore.dir/param_mod.f.o
[ 4%] Building Fortran object model/CMakeFiles/mfixcore.dir/param1_mod.f.o
[ 4%] Building Fortran object model/CMakeFiles/mfixcore.dir/GhdTheory/bulk_viscosity.f.o
[ 4%] Building Fortran object model/CMakeFiles/mfixcore.dir/visc_s_mod.f.o
[ 4%] Building Fortran object model/CMakeFiles/mfixcore.dir/fldvar_mod.f.o
[ 6%] Building Fortran object model/CMakeFiles/mfixcore.dir/cartesian_grid/progress_bar_mod.f.o
[ 4%] Building Fortran object model/CMakeFiles/mfixcore.dir/GhdTheory/chi_ij_GHD.f.o
[ 6%] Building Fortran object model/CMakeFiles/mfixcore.dir/vshear_mod.f.o
[ 6%] Building Fortran object model/CMakeFiles/mfixcore.dir/des/resize.f.o
[ 4%] Building Fortran object model/CMakeFiles/mfixcore.dir/parallel_mod.f.o
[ 4%] Building Fortran object model/CMakeFiles/mfixcore.dir/GhdTheory/pressure.f.o
[ 4%] Building Fortran object model/CMakeFiles/mfixcore.dir/adjust_leq.f.o
[ 4%] Building Fortran object model/CMakeFiles/mfixcore.dir/trace_mod.f.o
[ 6%] Building Fortran object model/CMakeFiles/mfixcore.dir/make_upper_case.f.o
[ 6%] Building Fortran object model/CMakeFiles/mfixcore.dir/visc_g_mod.f.o
[ 7%] Building Fortran object model/CMakeFiles/mfixcore.dir/cdist_mod.f.o
[ 7%] Building Fortran object model/CMakeFiles/mfixcore.dir/scales_mod.f.o
[ 7%] Building Fortran object model/CMakeFiles/mfixcore.dir/cartesian_grid/quadric_mod.f.o
[ 5%] Building Fortran object model/CMakeFiles/mfixcore.dir/dmp_modules/compar_mod.f.o
[ 7%] Building Fortran object model/CMakeFiles/mfixcore.dir/mflux_mod.f.o
[ 6%] Building Fortran object model/CMakeFiles/mfixcore.dir/des/particle_filter_mod.f.o
[ 7%] Building Fortran object model/CMakeFiles/mfixcore.dir/tau_g_mod.f.o
[ 7%] Building Fortran object model/CMakeFiles/mfixcore.dir/qmomk/qmomk_tools_mod.f.o
[ 6%] Building Fortran object model/CMakeFiles/mfixcore.dir/des/sq_rotation.f.o
[ 7%] Building Fortran object model/CMakeFiles/mfixcore.dir/cartesian_grid/polygon_mod.f.o
[ 7%] Building Fortran object model/CMakeFiles/mfixcore.dir/tau_s_mod.f.o
[ 7%] Building Fortran object model/CMakeFiles/mfixcore.dir/qmomk/qmomk_parameters_mod.f.o
[ 7%] Building Fortran object model/CMakeFiles/mfixcore.dir/cartesian_grid/dashboard_mod.f.o
[ 7%] Building Fortran object model/CMakeFiles/mfixcore.dir/turb_mod.f.o
[ 7%] Building Fortran object model/CMakeFiles/mfixcore.dir/des/sq_obb.f.o
[ 7%] Building Fortran object model/CMakeFiles/mfixcore.dir/get_walls_bc.f.o
[ 7%] Building Fortran object model/CMakeFiles/mfixcore.dir/remove_comment.f.o
[ 7%] Building Fortran object model/CMakeFiles/mfixcore.dir/des/sq_gmres.f.o
[ 7%] Building Fortran object model/CMakeFiles/mfixcore.dir/dqmom/gaussj.f.o
[ 7%] Building Fortran object model/CMakeFiles/mfixcore.dir/get_flow_bc.f.o
[ 7%] Building Fortran object model/CMakeFiles/mfixcore.dir/usr_mod.f.o
[ 8%] Building Fortran object model/CMakeFiles/mfixcore.dir/dgtsl.f.o
[ 8%] Building Fortran object model/CMakeFiles/mfixcore.dir/rrates.f.o
[ 8%] Building Fortran object model/CMakeFiles/mfixcore.dir/thermochemical/get_values.f.o
[ 8%] Building Fortran object model/CMakeFiles/mfixcore.dir/usr_read_namelist.f.o
[ 8%] Building Fortran object model/CMakeFiles/mfixcore.dir/usr_write_out0.f.o
[ 8%] Building Fortran object model/CMakeFiles/mfixcore.dir/usr_write_out1.f.o
[ 9%] Building Fortran object model/CMakeFiles/mfixcore.dir/write_usr1.f.o
[ 9%] Building Fortran object model/CMakeFiles/mfixcore.dir/write_usr0.f.o
[ 9%] Building C object model/CMakeFiles/mfixcore.dir/xpow.c.o
[ 9%] Building Fortran object model/CMakeFiles/mfixcore.dir/ODEPACK.F.o
/opt/software/anaconda3/envs/mfix-23.1.1/share/mfix/src/model/xpow.c:1:0: error: bad value (haswell) for -march= switch
/* xpow.c - replacement pow() function that detects integer and dyadic exponents
gmake[2]: *** [model/CMakeFiles/mfixcore.dir/xpow.c.o] Error 1
gmake[2]: *** Waiting for unfinished jobs…
gmake[1]: *** [model/CMakeFiles/mfixcore.dir/all] Error 2
gmake: *** [all] Error 2
                 BUILD FAILED
why is it? and i use the mfix-22.2.2 it works well.
I think we went over this already at https://mfix.netl.doe.gov/forum/t/the-case-run-well-in-mfix-22-1-but-has-error-in-mfix-22-2-2/4629/4
Ha…yes, I changed the computer, and forgot it …
This should be improved in the upcoming 23.3 release.
look forward to it…
and it will convenient for us to use mfix if you make the mpi and other dependent components be a set and integrated into mfix…so it will be easy to install the mfix.
hope to consider this suggestion, now it is difficult for me to use dmp…
Yes, the Conda package for 23.3 will include OpenMPI (except on Windows where it is not available) and the required Fortran and C compilers.
