OS: ubuntu16 (Virtual Machine)
mfix: 19.3.1 post0
The main issue is " Could NOT find MPI (missing: MPI_C_FOUND) (found version “3.0”)"
erro:
cmake -DENABLE_PYMFIX=ON -DENABLE_MPI=1 -G Unix Makefiles -DCMAKE_INSTALL_PREFIX=/home/cl/MFiX_Cases/git_sync/Yin_0413_git_sync_case -DPython3_ROOT_DIR=/home/cl/anaconda3/envs/mfix-19.3.1 -DUDF_DIR=/home/cl/MFiX_Cases/git_sync/Yin_0413_git_sync_case -DVERSION=19.3.1.post0 /home/cl/anaconda3/envs/mfix-19.3.1/share/mfix/src
– Build type = RelWithDebInfo
– CMake version = 3.16.4
– Fortran compiler =
– Fortran flags =
– ENABLE_MPI = 1
– ENABLE_OpenMP = OFF
– ENABLE_NETCDF = OFF
– ENABLE_CTEST = OFF
– ENABLE_COVERAGE = OFF
– The C compiler identification is GNU 5.4.0
– The Fortran compiler identification is GNU 5.4.0
– Check for working C compiler: /usr/bin/cc
– Check for working C compiler: /usr/bin/cc – works
– Check for working Fortran compiler: /usr/bin/gfortran
– Check for working Fortran compiler: /usr/bin/gfortran – works
– Checking whether /usr/bin/gfortran supports Fortran 90
– Checking whether /usr/bin/gfortran supports Fortran 90 – yes
– Could NOT find MPI_C (missing: MPI_C_WORKS)
– Found MPI_Fortran: /usr/lib/openmpi/lib/libmpi_usempif08.so (found version “3.0”)
CMake Error at /home/cl/anaconda3/envs/mfix-19.3.1/share/cmake-3.16/Modules/FindPackageHandleStandardArgs.cmake:146 (message):
/home/cl/anaconda3/envs/mfix-19.3.1/share/cmake-3.16/Modules/FindPackageHandleStandardArgs.cmake:393 (_FPHSA_FAILURE_MESSAGE)
/home/cl/anaconda3/envs/mfix-19.3.1/share/cmake-3.16/Modules/FindMPI.cmake:1700 (find_package_handle_standard_args)
model/CMakeLists.txt:619 (find_package)
See also “/home/cl/MFiX_Cases/git_sync/Yin_0413_git_sync_case/build/CMakeFiles/CMakeOutput.log”.
See also “/home/cl/MFiX_Cases/git_sync/Yin_0413_git_sync_case/build/CMakeFiles/CMakeError.log”.
BUILD UNSUCCESSFUL
case:
tutorial/dem/fluid_bed_dem_2d
description:
building SMP suceed, but DMP failed.
