Fluidized Bed - pressure
Hello, everyone, I am a new user of MFiX, and I am simulating a 2D fluidized bed. I am trying to measure the pressure at different heights. In other software I used, I could create planes at different heights and obtain the average pressure on these planes. Is it possible to do something similar in MFiX? Or should I get the pressure values at these heights during post-processing, for example, using Paraview?
You can do this by setting up monitors. Use the “Regions” plane to define the planes and then use “Montors” to create pressure monitors for the regions you defined.
The output will be a CSV file that you can plot internally in MFiX or load/examine with other software
