How do I output heat flux in postmfix? I do not see any heat flux export options inside MFix either. It is not simple as the numerical framework involves an in-simulation calculated heat transfer coefficient which is used with the temperature difference to drive the heat flux.
How do I obtain the heat flux at a boundary?
The simulation is a rectangular 2D domain. One wall is kept at constant temperature.
