Hello everyone.
I have a question regarding heterogeneous chemical kinetics in MFix-DEM: is it possible to define gas-solid reactions of the form A(s)+B(g) → C(s)+D(g), i.e. the reaction of a solid species A and a gaseous species B that turn into a solid species C and a gaseous species D?
I saw an equation in Table 2 of this article involving Xn. Is this the mass fraction of species n in the particle and is this equation solved for every particle?
Xn is mass fraction and to the best of my knowledge this is solved for each particle - as particles in different parts of the domain will be exposed to different reactants.
The limits on what types of reactions are permissible are a bit complex. The MFiX GUI will try to guide you and not allow you to define unpermitted reactions. However sometimes you can still set something up that will be rejected by the solver when you run the simulation. My advice is just to try it and see what happens. Here’s the exact rules:
Reaction Restrictions
Heterogeneous reactions referencing three or more phases:
Either only one phase has a net mass loss or one phase
has a net mass gain. Specifically, two or more phases cannot
have a net mass loss while two or more phases have a net mass
gain.
The following examples illustrate valid and invalid reactions. For
these examples, FC1, FC2, and sSoot, represent solid carbon in
solids phases 1, 2 and 3, respectively. All other species belong
to the gas.
Example 1: VALID
2*FC1 + O2 → 2CO
One phase has a net mass loss,
one phase has a net mass gain
Example 2: VALID
FC1 + FC2 + O2 → 2CO
Two phases have a net mass loss,
Example 3: VALID
2.2FC1 + O2 → 2CO + 0.2sSoot
two phases have a net mass gain
Example 4: INVALID
1.1FC1 + 1.1FC2 + O2 → 2CO + 0.2*sSoot
The heat of reaction, DH, and how it is distributed between phases,
fracDH, must be specified if there are two or more solids phases
listed as either reactants or products.
In MFix-DEM, is it possible to simulate the following reaction?
Species A remains species A until a nucleus of species B appears on its surface, whereupon the entire particle is instantaneously converted into species B.
The appearance of the nucleus is a probabilistic process and the nucleation time tau is exponentially distributed.
Is it possible to access the time stepdt of the numerical solver of MFix-DEM?
I would like to define the reaction rate as follows:
generate a potential nucleation time tau via random numbers
if tau < dt, the nucleus appears and species A is instantaneously transformed into species B. I would set a very large value for the reaction rate.
if tau > dt, nothing happens and rate = 0.
However, in order for that solution to work, I must be able to use the numerical time step of Mfix-DEM in my definition of the heterogeneous reaction rate.
Is this possible?
I thank you very much ahead of time for your answer!
Hi @cgw,
Could you clarify example 5 here and the meaning of FC2, as it is not really mentioned in the equation? Is the meaning of this the 0.2sSoot on the product side? It is still referenced this way in the current docs. (I was hesitating for a while to create a new thread on this to clarify.)
