When I set fluid velocity of mass inflow as 1m/s or 10m/s, it showed me the following errors. How can I configure the maximum allowed gas velocities? Thank you.
mfix - WARNING - velocity higher than maximum allowed velocity: 100.00 mfix - WARNING - velocity higher than maximum allowed velocity: 100.00
I have the same problem, and the text only shows this message:
WARNING: velocity higher than maximum allowed velocity (to change this adjust the scale factor MAX_INLET_VEL_FAC)
DT < DT_MIN. Recovery not possible
