Need to check the overconsumption in each cell for a case with csg.
Is there a way to check whether a cell is a full cell or a cut cell in the mfix_usr_reactions_rates_K.H ?
And how to get the cell volume of the cut cell in the mfix_usr_reactions_rates_K.H?
Currently checking if a cell is covered or cut is not supported in mfix_usr_reactions_rates_K.H but it can be added if needed.
You can get cell volume and volume fraction by respectively reactions.cell_volume() and reactions.vfrac() in either eulerian or lagrangian reaction rates
Thanks Roberto, can reactions.cell_volume() get the cell volume of a cut cell?
To get the volume of a cut cell you need to multiply cell_volume by vfrac, aka:
amrex::Real effective_cell_volume = reactions.cell_volume()*reactions.vfrac();
Isn’t just checking if reactions.vfrac() > 1 - small_number what @YupengXu is asking when he wants to check for full (uncut) cells?
That might work but it isn’t the most efficient way. I think that if checking whether a cell is cut or regular is really needed in reaction rates, it would be best to just add the needed functions and data to the classes used in chemistry.
While I’m not strenuously opposed to making cell flag data available to the reactions UDF, I think it may encourage bad practices in implementing reaction rate expressions. Specifically, reactions should not be treated differently in cut-cut cells (i.e., !flag(i,j,k).isRegular()).
