Hello, developers,I would like to ask why my ”chemical“ interface is gray?How to use ”chemistry“ normally?
Looking forward to any possible answers! Thank you very much!
Chemistry is enabled when there are more than one species defined. Without species to react, there can be no reactions.
Thank you very much for your answer!But how to define multiple species?Sorry,I didn’t know much because I first started learning MFIX.
Fluid species are defined in the Fluid pane, solids in the Solids pane.
I suggest you take a look at some of the “Reacting flows” tutorials:
https://mfix.netl.doe.gov/doc/mfix/23.1/html/tutorials/advanced_tutorials.html
