Hi Dear All,
I run the CFD-DEM simulation by the source code MFIX. Then the run stopped because of other unpredicted reasons, like the update of the system. I modified run_type in mfix.dat from “New” to “Restart_1”. I always got the below error. At this instant the particle number in the bed is about149,800. Because there are too many particles in the bed? or the problem of the memory limit? Res file was destroyed? I am using MFIX-18.1.1. Any clue? Thank you so much.
Best,
Leina
