There are two solid phase. One is dominating and another is minor. So I whant to ignore the collison of the secondary particle while retaining the collision of the primiary particle. I need to modify the code of Mfix. How can I do this?
If you are using DEM, I do not suggest to do so, because if you do not consider the collision between particles, unphysical large overlap can happen. You can try the hybrid model (TFM+DEM) or PIC for both solids.
Have you figure out a feasible way to implement this idea in MFIX?
