Hi Dear ALL,
I want to implement a BC at the column inlet at which the gas vekocity decreases with the time. What kind of *.f or keywords shoud I use? Thank you so much.
Best,
Leina
Hi Dear ALL,
Best,
Leina
See similar topics, you might find a solution.
Gaoxi, thank you so much. I found the solution:)
Hi Gaoxi, I got this when I am trying to compile usr1.f. This warning will affect the results? Thank you.
It seems that the clock on the build machine is out of sync with the timestamps on the source files. (you might find a solution online)
I suggest:
make clean ! to remove previous .o files
make -j ! make again and try
Yes, the warning disappears when I try:
make clean
make -j
Thank you
Hi Gaoxi, I got this error. Could you give me any reminder? Thank you.
Is that because bc_p_g(1)=101325 was not defined ?
Thank Gaoxi. I will try it later.
