How to import .msh file generated by other softwares
Thank you Jeff. I am currently trying to do meshing for chamber with delicate structures. Sometimes, the quality of generated mesh by either control point or uniform method is bad, and sometimes, the “index, dimension 1, above upper bounds” type error would happen for some configuration of cell numbers in each direction or points position for control point method.
And as you say, the cut-cell method is challenging for this kind of model, whether the other meshing methods can be selected. I hereby attach the .stl and .mfx files. Thank you.
chamber_delicate_structure1.mfx (8.3 KB)
chamber_delicate_structure2.STL (766.9 KB)
