I am trying to simulate a process that the particle phase is static in the domain while the fluid passes through the particle layer. There are species transport between the fluid and solid phase. Now I use usr1_des to set the contact forces, gravity, and drag force as zero to keep particles static. However, the DEM solver still costs 4 s of 203 disperse particles each iteration.
I am thinking about whether there is a good way to accelerate this process.
I saw someone’s code solving this by defining a box region, and defining the solid particles to be in that region with max packed-bed volume fraction. That way the solid doesn’t move at all. But it messes up the pressure.
