How to move Internal surface for DEM simulation
Hi (@gbotha, @gbotha Gerrit Botha),
I am trying to assign a constant velocity in X direction to internal surface for DEM Simulation. The internal surface is in between the solid grains. I followed your discussion ‘DEM Particles with unrealistic high velocity’. Could you please guide me?
Thank you very much.
Regards,
Bimal Chhushyabaga
Hello Bimal,
Have you studied the rotating drum (3D) setup? It may have solutions to the questions you may have on implementing a moveable internal surface.
Hi @oyedejifemi,
Thank you very much for the information. I will go through rotating drum (3D) setup.
Regards,
Bimal Chhushyabaga
