I tried to output all the contacts (i.e., the position of the particle in contact) and contact forces between particles at intervals. I have used user scalar to output the particle information. However, the contact information is different and seems unable to be outputted by user scalar.
Sincerely thanks the instructions from the experts proficient in DEM.
Thanks very much for your reply. I am Chinese. Could you explain in brief why the same variable, i.e., sqrt(…) are stored in DES_USR_VAR with two different indexes?
In my opinion, the value of DES_USR_VAR is stored as particle information. If one particle has two or more contacts, how can I output all contact forces exerted on the particle
Could you please explain this code. I need a similar code to output single particle drag coefficient.
