This is not an error. The message is telling you that BC_Uw_s is not compatible with DEM. Not all options are compatible with all models. If a message is telling you that an input is illegal for DEM/PIC, then you are not able to use that input. The message is fairly explicit, but if you want more detail you can look at the section of code mentioned in the error message: (check_data\check_bc_walls.f)
