Hi Dear All,
I want to set the maximum solid volume fraction in MFIX-DEM by mfix.dat. No GUI is used. So which key parameter shoudl I use? Or what is the default value of the maximum solid volume fraction? Thank you so much.
Best wishes,
Leina
Hi Dear All,
Best wishes,
Leina
Try the keyword EP_STAR, the gas phase volume fraction in a cell is computed as
EP_G(IJK) = ONE - min(PACKED_EPS, SUM_EPS)
where,
PACKED_EPS = ONE
IF(MPPIC) THEN
PACKED_EPS = 0.9D0
ELSEIF(EP_STAR/=UNDEFINED) THEN
PACKED_EPS = ONE - EP_STAR
ENDIF
Gaoxi, thank you for your response. I will try it.
