If you make particles move in a viscoelastic fluid, how do you set up a non-Newtonian fluid? Because I think the fluid setting under the DEM model can only select a steady viscosity, how to achieve real-time changes in viscosity
I don’t think there is built-in support for this in MFiX, you will have to write some custom code.
