I dont know if I was clear in my query. I am rephrasing my question again -
I want to use the dimensionless form of DEM equation, where I will be giving all the parameters in non-dimension form like K(spring constant), time (collision time), S(intersurface distance), V(velocity) … all will be given in Non-Dimensional form.
Why I want to use non-dimensional form ?
For particle size less than 0.1 micron , collision time goes down drastically to the value of 10^-12 s. To take care of this very low time scale, Dimensionless equation reduce down time to the 10^-9 range.
it sounds like they or you are making a mistake in the nondimensionalization of the governing equations. you shouldn’t get anything for free in nondim form. true you can scale it to make dt arbitrarily large, but then the same scaling should apply to tstop so you end up with an equal amount of computation to get the same nondim. result.
