Hello Guys,
when trying to install Mfix in windows this error occurs. Appreciate any help on this.
Thank you
Hello Guys,
Thank you
Hi @william321
Firstly, we would prefer if you didn’t post the download codes here in the forum.
Secondly, these codes have a built-in expiration, so you may need to get a new code from the download page (you must be a registered user to access this).
Finally, if a new code does not work, post the output of “conda info” here.
Thanks.
Hello Charles,
My apologies for posting the codes, that was clumsy of me. I will try to install it again and get back to you.
Thank you.
Already tried installing it again and the same error appears both on my laptop and PC.
I don’t know how to tell if I’m a registered user but what I do after logging-in is go to products>MFiX download then the instructions of how to download and install appears.
here is the output of “conda info”
(base) C:\WINDOWS\system32>conda info
active environment : base
active env location : C:\Users\admin\miniforge3
shell level : 1
user config file : C:\Users\admin\.condarc
populated config files : C:\Users\admin\miniforge3.condarc
conda version : 26.7.0
conda-build version : not installed
python version : 3.13.13.final.0
solver : libmamba (default)
virtual packages : __archspec=1=haswell
__conda=26.7.0=0
__cuda=10.1=0
__win=10.0.19045=0
base environment : C:\Users\admin\miniforge3 (writable)
conda av data dir : C:\Users\admin\miniforge3\etc\conda
conda av metadata url : None
channel URLs : conda-forge/win-64
package cache : C:\Users\admin\miniforge3\pkgs
C:\Users\admin.conda\pkgs
C:\Users\admin\AppData\Local\conda\conda\pkgs
notices cache : C:\Users\admin\AppData\Local\conda\conda\Cache\notices
envs directories : C:\Users\admin\miniforge3\envs
C:\Users\admin.conda\envs
C:\Users\admin\AppData\Local\conda\conda\envs
temporary directory : C:\Users\admin\AppData\Local\Temp
platform : win-64
user-agent : conda/26.7.0 requests/2.34.2 CPython/3.13.13 Windows/10 Windows/10.0.19045 solver/libmamba conda-libmamba-solver/26.4.2 libmambapy/2.5.0
administrator : True
netrc file : None
offline mode : False
Regards,
William
If you’re using a fresh download code and still getting a 403, I’m not sure what the issue is. Arw you behind a web proxy of some sort?
Your right about having some kind of web proxy, not really sure what it is, but when I used another way of connecting to the internet the installation was a success.
Thank you for the help.
-William
