Implementation of solid bridge force
Hi DEM Developers,
I want to cooperate the solid bridge force to simulate the particle aggregation for thermochemical particles fluidisation.
I can calculate the solid bridge force in the normal and tangential direction.
My question is is there a collision force in the tangential direction. So I could judge the two particles will break in the tangential direction or the normal direction.
If the two particles sticks together, what parameter should I change to keep the two particles share same velocity and movement.
How should i consider the rotation effect?
Kind regards
Yuanhe
