Hi, Mfix community
I’ve been simulating some cases based on tutorial 3.2 TFM and I find in the EPgErr file the text:
One or more cells have reported a negative gas volume fraction (EP_g).
I am not getting any message of error during the simulation. What does this message mean about the simulation? Does it mean the solution is diverging?
However, I get the following message in the beginning:
INFO C:\tools\miniconda3\conda-bld\mfix-solver_1556302768954\work\model\set_bc0.f:575
Outflow PC defined: IJK_P_g remaining undefined
which I also do not understand, since the bc_p_g(BC) is defined. I am attaching herewith the .mfx file. The mesh in the file is coarse and I am willing to run several simulations to understand when the solution becomes independent of the mesh configuration. Thank you!
cvm1.mfx (13.5 KB)
