Hello everyone, can you help me solve this problem? I installed MFix based on Miniforge 3. Why does this error occur when I open the case in the software? Is there a problem with my installation?
This is not an installation error, but a problem with the case you are opening. Somehow the file .graphics (hidden file, starting with a dot) in the project directory is incorrect. Can you post the contents of this file so we can see what the problem is? Or do a “Submit bug report” from the main menu and attach the ZIP file.
Note that you can safely ignore this error and continue, the case should run OK, but the previous graphics settings will not be restored.
Can you please tell us what version of MFiX this is, and upload the .graphics file?
