!(file:///D:\用户目录\我的文档\Tencent Files\1433257140\FileRecv\MobileFile\IMG_20190506_132347.jpg)
hello ,everyone !
as the picture shows, I installed the mfix-19.1 in the win-10 64-bit , and I met the problem when I was opening the mfix in the terminal . Then I can’t open the mfix-19.1 successfully because it was forcibly closed after the above information apperaed .
Could anyone help me ?
There may be some problem with the OpenGL drivers on your system. Try running MFiX as:
C:\> mfix --novtk
And you should be able to use the MFiX GUI and solver, though not VTK visualization.
To get VTK working, try updating the OpenGL drivers on your system.
Thanks , that’s it . The problem has been solved after I update the drivers .
