Hi, I tried to install Nodeworks on WinPython distribution using Poetry (I cannot install Miniconda or Conda for various reasons).
I received this message during installation “poetry install”:
Package operations: 10 installs, 1 update, 0 removals
- Updating pyqt5-qt5 (5.15.2 -> 5.15.16): Failed
| Unable to find installation candidates for pyqt5-qt5 (5.15.16)
| This is likely not a Poetry issue.
| - 4 candidate(s) were identified for the package
| - 4 wheel(s) were skipped as your project's environment does not support the identified abi tags
| Solutions:
| Make sure the lockfile is up-to-date. You can try one of the following;
| 1. Regenerate lockfile: poetry lock --no-cache --regenerate
| 2. Update package : poetry update --no-cache pyqt5-qt5
| If neither works, please first check to verify that the pyqt5-qt5 has published wheels available from your configured source that are compatible with your environment- ie. operating system, architecture (x86_64, arm64 etc.), python interpreter.
| You can also run your poetry command with -v to see more information.
And this message when I tried to launch it “poetry run nodeworks”:
File "<string>", line 1, in <module>
File "C:\Users\...\WPy64-31290\python\Lib\importlib\__init__.py", line 90, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
File "<frozen importlib._bootstrap>", line 1310, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
File "<frozen importlib._bootstrap>", line 1324, in _find_and_load_unlocked
ModuleNotFoundError: No module named 'nodeworks'
If I go back to “nodeworks-23.1.0” path evel, and not in the “nodeworks” folder level, I receive this message:
No module named 'qtpy'
File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 999, in exec_module
File "C:\Users\...WPy64-31290\_others\nodeworks-23.1.0\nodeworks\app.py", line 17, in <module>
import qtpy
ModuleNotFoundError: No module named 'qtpy'
What I did Wrong?
Thanks. have a nice day.
