Installation problem
hello , everyone!
when I install mfix-19.1 on win-10 ,I met the problem as the following :
(base) C:\Users\admin>conda env create -n mfix-19.1 mfix/mfix-19.1-win64
WARNING: The conda.compat module is deprecated and will be removed in a future release.
# >>>>>>>>>>>>>>>>>>>>>> ERROR REPORT <<<<<<<<<<<<<<<<<<<<<<
      File "D:\software\conda\conda\lib\site-packages\urllib3\connection.py", line 159, in _new_conn
        (self._dns_host, self.port), self.timeout, **extra_kw)
      File "D:\software\conda\conda\lib\site-packages\urllib3\util\connection.py", line 57, in create_connection
        for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
      File "D:\software\conda\conda\lib\socket.py", line 748, in getaddrinfo
        for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
    socket.gaierror: [Errno 11001] getaddrinfo failed
    During handling of the above exception, another exception occurred:
      File "D:\software\conda\conda\lib\site-packages\urllib3\connectionpool.py", line 600, in urlopen
        chunked=chunked)
      File "D:\software\conda\conda\lib\site-packages\urllib3\connectionpool.py", line 343, in _make_request
        self._validate_conn(conn)
      File "D:\software\conda\conda\lib\site-packages\urllib3\connectionpool.py", line 839, in _validate_conn
        conn.connect()
      File "D:\software\conda\conda\lib\site-packages\urllib3\connection.py", line 301, in connect
        conn = self._new_conn()
      File "D:\software\conda\conda\lib\site-packages\urllib3\connection.py", line 168, in _new_conn
        self, "Failed to establish a new connection: %s" % e)
    urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x000002A7CE3F70B8>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed
      File "D:\software\conda\conda\lib\site-packages\requests\adapters.py", line 449, in send
        timeout=timeout
      File "D:\software\conda\conda\lib\site-packages\urllib3\connectionpool.py", line 638, in urlopen
        _stacktrace=sys.exc_info()[2])
      File "D:\software\conda\conda\lib\site-packages\urllib3\util\retry.py", line 398, in increment
        raise MaxRetryError(_pool, url, error or ResponseError(cause))
    urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='api.anaconda.org', port=443): Max retries exceeded with url: /package/mfix/mfix-19.1-win64 (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x000002A7CE3F70B8>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed'))
      File "D:\software\conda\conda\lib\site-packages\conda\exceptions.py", line 1003, in __call__
        return func(*args, **kwargs)
      File "D:\software\conda\conda\lib\site-packages\conda_env\cli\main.py", line 73, in do_call
        exit_code = getattr(module, func_name)(args, parser)
      File "D:\software\conda\conda\lib\site-packages\conda_env\cli\main_create.py", line 77, in execute
        directory=os.getcwd())
      File "D:\software\conda\conda\lib\site-packages\conda_env\specs\__init__.py", line 40, in detect
        if spec.can_handle():
      File "D:\software\conda\conda\lib\site-packages\conda_env\specs\binstar.py", line 45, in can_handle
        result = self._can_handle()
      File "D:\software\conda\conda\lib\site-packages\conda_env\specs\binstar.py", line 60, in _can_handle
        return self.package is not None and self.valid_package()
      File "D:\software\conda\conda\lib\site-packages\conda_env\specs\binstar.py", line 114, in package
        self._package = self.binstar.package(self.username, self.packagename)
      File "D:\software\conda\conda\lib\site-packages\binstar_client\__init__.py", line 301, in package
        res = self.session.get(url)
      File "D:\software\conda\conda\lib\site-packages\requests\sessions.py", line 546, in get
        return self.request('GET', url, **kwargs)
      File "D:\software\conda\conda\lib\site-packages\requests\sessions.py", line 533, in request
        resp = self.send(prep, **send_kwargs)
      File "D:\software\conda\conda\lib\site-packages\requests\sessions.py", line 646, in send
        r = adapter.send(request, **kwargs)
      File "D:\software\conda\conda\lib\site-packages\requests\adapters.py", line 516, in send
        raise ConnectionError(e, request=request)
    requests.exceptions.ConnectionError: HTTPSConnectionPool(host='api.anaconda.org', port=443): Max retries exceeded with url: /package/mfix/mfix-19.1-win64 (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x000002A7CE3F70B8>: Failed to establish a new connection: [Errno 11001] getaddrinfo failed'))
`$ D:\software\conda\conda\Scripts\conda-env-script.py create -n mfix-19.1 mfix/mfix-19.1-win64`
  environment variables:
                 CIO_TEST=<not set>
  CONDA_AUTO_UPDATE_CONDA=false
        CONDA_DEFAULT_ENV=base
                CONDA_EXE=D:\software\conda\conda\condabin\..\Scripts\conda.exe
               CONDA_EXES="D:\software\conda\conda\condabin\..\Scripts\conda.exe"
             CONDA_PREFIX=D:\software\conda\conda
    CONDA_PROMPT_MODIFIER=(base)
               CONDA_ROOT=D:\software\conda\conda
              CONDA_SHLVL=1
                 HOMEPATH=\Users\admin
                     PATH=D:\software\conda\conda\condabin\..;D:\software\conda\conda\condabin\.
                          .\Library\mingw-w64\bin;D:\software\conda\conda\condabin\..\Library\us
                          r\bin;D:\software\conda\conda\condabin\..\Library\bin;D:\software\cond
                          a\conda\condabin\..\Scripts;D:\software\conda\conda\condabin\..\bin;D:
                          \software\conda\conda;D:\software\conda\conda\Library\mingw-w64\bin;D:
                          \software\conda\conda\Library\usr\bin;D:\software\conda\conda\Library\
                          bin;D:\software\conda\conda\Scripts;D:\software\conda\conda\bin;D:\sof
                          tware\conda\conda\condabin;C:\Windows\system32;C:\Windows;C:\Windows\S
                          ystem32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\Sy
                          stem32\OpenSSH\;C:\Users\admin\.dnx\bin;C:\Program Files\Microsoft
                          DNX\Dnvm\;C:\Users\admin\AppData\Local\Microsoft\WindowsApps;
             PSMODULEPATH=C:\Program Files\WindowsPowerShell\Modules;C:\Windows\system32\Windows
                          PowerShell\v1.0\Modules
       REQUESTS_CA_BUNDLE=<not set>
            SSL_CERT_FILE=<not set>
     active environment : base
    active env location : D:\software\conda\conda
            shell level : 1
       user config file : C:\Users\admin\.condarc
 populated config files : C:\Users\admin\.condarc
          conda version : 4.6.11
    conda-build version : 3.17.8
         python version : 3.7.3.final.0
       base environment : D:\software\conda\conda  (writable)
           channel URLs : https://repo.anaconda.com/pkgs/main/win-64
                          https://repo.anaconda.com/pkgs/main/noarch
                          https://repo.anaconda.com/pkgs/free/win-64
                          https://repo.anaconda.com/pkgs/free/noarch
                          https://repo.anaconda.com/pkgs/r/win-64
                          https://repo.anaconda.com/pkgs/r/noarch
                          https://repo.anaconda.com/pkgs/msys2/win-64
                          https://repo.anaconda.com/pkgs/msys2/noarch
          package cache : D:\software\conda\conda\pkgs
                          C:\Users\admin\.conda\pkgs
                          C:\Users\admin\AppData\Local\conda\conda\pkgs
       envs directories : D:\software\conda\conda\envs
                          C:\Users\admin\.conda\envs
                          C:\Users\admin\AppData\Local\conda\conda\envs
               platform : win-64
             user-agent : conda/4.6.11 requests/2.21.0 CPython/3.7.3 Windows/10 Windows/10.0.17134
          administrator : False
             netrc file : None
           offline mode : False
If submitted, this report will be used by core maintainers to improve
future releases of conda.
Would you like conda to send this report to the core maintainers?
[y/N]:
Could anyone help me solve this problem ? Thanks !
Does it need network connection for activating the mfix-19.1 environment ?
The command
requires a network connection; check your connection and try again.
Thanks , that’s it . The problem has been solved.
