Installation problems with Nodeworks
I have a problem with the installation after changing the computer and system (from win10 to win7).
Here is the system response after trying to install NodeWorks.
(base) C:\Users\Karol>conda install nodeworks -c mfix -c …
UnavailableInvalidChannel: The channel is not accessible or is invalid.
channel name: dist
channel url: https://mfix.netl.doe.gov/conda/dist
error code: 404
You will need to adjust your conda configuration to proceed.
Use conda config --show channels to view your configuration’s current state,
and use conda config --show-sources to view config file locations.
How can you fix this?
Regards
Mimru
I fixed the link. Please refresh the download page and try again.
Hi…
Thank you very much for your help.
Everything installs and works well.
Regards
Mimru
