Hi, I am running 2D TFM fluidized bed.
As you can see in the attached file,
I inserted 2e-4 meter solid particle.
My question is, can I input multiple solid particle sizes in TFM model?
Hi,it seems that you wish to add multi-phase particles when restart?
If you have not provide all the particle phases at the beginning, you can not add it when restart.
I think you can set all the solid phases you need when initialising and then you can modify the mass faction at the inlet when restart the case.
Regards
Dear CFD_Infant
Thank you for your reply!
I was not talking about multi-phase particles.
I want to put different sizes of solid particles.
For example, 100 micron 10%
200 micron 20%
300 micron 50%
400 micron 20%
solid particle with different sizes.
I think you can click ‘+’ in the solid tab to set different diameters of solid phases
Kind regards
Thank you! I got it!
