“I want to run a 2D pyrolysis example, but there’s a file with a Korean name in the existing file path, which is causing an error. So, when I try to change the path to create the example, I’m encountering an error where MFIX doesn’t respond. How can I resolve this?”
What platform are you running on - Windows or Linux? Unicode path names should be supported, but we don’t always test this. Can you tell me what the path name is, and what the error message is?
