I have 2 separate walls. One of them is free slip for both phases and the other one is No-slip for the fluid and Partial slip for the solid.
The interesting point is that when I set the value for the restitution coefficient and specularity for the solid phase in partial wall, they would exactly be copied to the other wall. Does it mean that I cannot define different values for the different walls???
Also when using free slip do I need to activate the JJ formulation with copied values from the partial wall or I need to just uncheck the JJ equation??
Hi Moshenclick. Can you attach your .mfx file?
