I’m getting the following error when I execute the installation command:
$ conda create -n mfix-19.2.2 mfix=19.2.2 mfix-doc=19.2.2 mfix-gui=19.2.2 mfix-solver=19.2.2 mfix-src=19.2.2 -c https://mfix.netl.doe.gov/s3/.../.../conda/dist
# >>>>>>>>>>>>>>>>>>>>>> ERROR REPORT <<<<<<<<<<<<<<<<<<<<<<
File "/home/klinkovsky/stuff/anaconda3/lib/python3.7/site-packages/conda/exceptions.py", line 1062, in __call__
return func(*args, **kwargs)
File "/home/klinkovsky/stuff/anaconda3/lib/python3.7/site-packages/conda/cli/main.py", line 84, in _main
exit_code = do_call(args, p)
File "/home/klinkovsky/stuff/anaconda3/lib/python3.7/site-packages/conda/cli/conda_argparse.py", line 82, in do_call
exit_code = getattr(module, func_name)(args, parser)
File "/home/klinkovsky/stuff/anaconda3/lib/python3.7/site-packages/conda/cli/main_create.py", line 37, in execute
install(args, parser, 'create')
File "/home/klinkovsky/stuff/anaconda3/lib/python3.7/site-packages/conda/cli/install.py", line 256, in install
force_reinstall=context.force_reinstall or context.force,
File "/home/klinkovsky/stuff/anaconda3/lib/python3.7/site-packages/conda/core/solve.py", line 112, in solve_for_transaction
force_remove, force_reinstall)
File "/home/klinkovsky/stuff/anaconda3/lib/python3.7/site-packages/conda/core/solve.py", line 150, in solve_for_diff
force_remove)
File "/home/klinkovsky/stuff/anaconda3/lib/python3.7/site-packages/conda/core/solve.py", line 249, in solve_final_state
ssc = self._collect_all_metadata(ssc)
File "/home/klinkovsky/stuff/anaconda3/lib/python3.7/site-packages/conda/common/io.py", line 88, in decorated
return f(*args, **kwds)
File "/home/klinkovsky/stuff/anaconda3/lib/python3.7/site-packages/conda/core/solve.py", line 389, in _collect_all_metadata
index, r = self._prepare(prepared_specs)
File "/home/klinkovsky/stuff/anaconda3/lib/python3.7/site-packages/conda/core/solve.py", line 974, in _prepare
self.subdirs, prepared_specs, self._repodata_fn)
File "/home/klinkovsky/stuff/anaconda3/lib/python3.7/site-packages/conda/core/index.py", line 214, in get_reduced_index
repodata_fn=repodata_fn)
File "/home/klinkovsky/stuff/anaconda3/lib/python3.7/site-packages/conda/core/subdir_data.py", line 91, in query_all
result = tuple(concat(executor.map(subdir_query, channel_urls)))
File "/home/klinkovsky/stuff/anaconda3/lib/python3.7/concurrent/futures/_base.py", line 586, in result_iterator
yield fs.pop().result()
File "/home/klinkovsky/stuff/anaconda3/lib/python3.7/concurrent/futures/_base.py", line 432, in result
return self.__get_result()
File "/home/klinkovsky/stuff/anaconda3/lib/python3.7/concurrent/futures/_base.py", line 384, in __get_result
raise self._exception
File "/home/klinkovsky/stuff/anaconda3/lib/python3.7/concurrent/futures/thread.py", line 57, in run
result = self.fn(*self.args, **self.kwargs)
File "/home/klinkovsky/stuff/anaconda3/lib/python3.7/site-packages/conda/core/subdir_data.py", line 87, in <lambda>
package_ref_or_match_spec))
File "/home/klinkovsky/stuff/anaconda3/lib/python3.7/site-packages/conda/core/subdir_data.py", line 96, in query
self.load()
File "/home/klinkovsky/stuff/anaconda3/lib/python3.7/site-packages/conda/core/subdir_data.py", line 160, in load
_internal_state = self._load()
File "/home/klinkovsky/stuff/anaconda3/lib/python3.7/site-packages/conda/core/subdir_data.py", line 262, in _load
_internal_state = self._process_raw_repodata_str(raw_repodata_str)
File "/home/klinkovsky/stuff/anaconda3/lib/python3.7/site-packages/conda/core/subdir_data.py", line 335, in _process_raw_repodata_str
json_obj = json.loads(raw_repodata_str or '{}')
File "/home/klinkovsky/stuff/anaconda3/lib/python3.7/json/__init__.py", line 348, in loads
return _default_decoder.decode(s)
File "/home/klinkovsky/stuff/anaconda3/lib/python3.7/json/decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/home/klinkovsky/stuff/anaconda3/lib/python3.7/json/decoder.py", line 353, in raw_decode
obj, end = self.scan_once(s, idx)
json.decoder.JSONDecodeError: Expecting property name enclosed in double quotes: line 1 column 144 (char 143)
`$ /home/klinkovsky/stuff/anaconda3/bin/conda create -n mfix-19.2.2 mfix=19.2.2 mfix-doc=19.2.2 mfix-gui=19.2.2 mfix-solver=19.2.2 mfix-src=19.2.2 -c https://mfix.netl.doe.gov/s3/1e53a227/ca9b80679840e2dc5332b0e21a8be976/conda/dist`
environment variables:
CCACHE_PATH=/usr/bin
CIO_TEST=<not set>
CONDA_ROOT=/home/klinkovsky/stuff/anaconda3
CUDA_CACHE_PATH=/home/klinkovsky/.cache/nv
CUDA_PATH=/opt/cuda
LD_LIBRARY_PATH=/home/klinkovsky/.local/lib:
MODULEPATH=/usr/share/modulefiles/Linux:/usr/share/modulefiles/Core:/usr/share/lm
od/lmod/modulefiles/Core
PATH=/home/klinkovsky/.local/bin:/home/klinkovsky/bin:/usr/local/sbin:/usr/
local/bin:/usr/bin:/opt/cuda/bin:/usr/lib/jvm/default/bin:/usr/bin/sit
e_perl:/usr/bin/vendor_perl:/usr/bin/core_perl:/home/klinkovsky/Script
s:/home/klinkovsky/stuff/anaconda3/bin
PKG_CONFIG_PATH=/home/klinkovsky/.local/share/pkgconfig:
PYTHONSTARTUP=/home/klinkovsky/.config/python/startup.py
REQUESTS_CA_BUNDLE=<not set>
SSL_CERT_FILE=<not set>
__GL_SHADER_DISK_CACHE_PATH=/home/klinkovsky/.cache/nv
active environment : None
user config file : /home/klinkovsky/.condarc
populated config files :
conda version : 4.7.10
conda-build version : 3.18.8
python version : 3.7.3.final.0
virtual packages : __cuda=10.1
base environment : /home/klinkovsky/stuff/anaconda3 (writable)
channel URLs : https://mfix.netl.doe.gov/s3/1e53a227/ca9b80679840e2dc5332b0e21a8be976/conda/dist/linux-64
https://mfix.netl.doe.gov/s3/1e53a227/ca9b80679840e2dc5332b0e21a8be976/conda/dist/noarch
https://repo.anaconda.com/pkgs/main/linux-64
https://repo.anaconda.com/pkgs/main/noarch
https://repo.anaconda.com/pkgs/r/linux-64
https://repo.anaconda.com/pkgs/r/noarch
package cache : /home/klinkovsky/stuff/anaconda3/pkgs
/home/klinkovsky/.conda/pkgs
envs directories : /home/klinkovsky/stuff/anaconda3/envs
/home/klinkovsky/.conda/envs
platform : linux-64
user-agent : conda/4.7.10 requests/2.22.0 CPython/3.7.3 Linux/5.2.9-arch1-1-ARCH arch/ glibc/2.29
UID:GID : 2000:2000
netrc file : None
offline mode : False
If submitted, this report will be used by core maintainers to improve
future releases of conda.
Would you like conda to send this report to the core maintainers?
[y/N]: ^C
Timeout reached. No report sent.
How could I install MFiX next? I would be very greatful for reply.
