MFiX 19.2 source tarball
Red Hat 7.6
When running the make command, I get the following “undefined reference” errors. Boost 1.68.0a is installed.
/cm/shared/apps/openmpi/gcc/64/1.10.7/bin/mpifort -O2 -g -O2 -g -DNDEBUG CMakeFiles/mfixsolver.dir/model/mfix.f.o -o mfixsolver model/libmfixcore.a model/cppmfix/libcppmfix.a /cm/local/apps/boost/1.68.0.a/lib64/libboost_filesystem.a /cm/local/apps/boost/1.68.0.a/lib64/libboost_regex.a /cm/local/apps/boost/1.68.0.a/lib64/libboost_system.a -lmpi_cxx -lstdc++
model/cppmfix/libcppmfix.a(cppmfix.cpp.o): In function path<boost::filesystem::directory_entry>': /usr/include/boost/filesystem/path.hpp:139: undefined reference to boost::filesystem::path_traits::dispatch(boost::filesystem::directory_entry const&, std::string&, std::codecvt<wchar_t, char, __mbstate_t> const&)’
/usr/include/boost/filesystem/path.hpp:139: undefined reference to boost::filesystem::path_traits::dispatch(boost::filesystem::directory_entry const&, std::string&, std::codecvt<wchar_t, char, __mbstate_t> const&)' model/cppmfix/libcppmfix.a(cppmfix.cpp.o): In function error_code’:
/usr/include/boost/system/error_code.hpp:315: undefined reference to boost::system::system_category()' model/cppmfix/libcppmfix.a(cppmfix.cpp.o): In function get_system_category’:
/usr/include/boost/asio/error.hpp:216: undefined reference to boost::system::system_category()' model/cppmfix/libcppmfix.a(cppmfix.cpp.o): In function error_code’:
/usr/include/boost/asio/error.hpp:216: undefined reference to boost::system::system_category()' /usr/include/boost/asio/error.hpp:216: undefined reference to boost::system::system_category()’
model/cppmfix/libcppmfix.a(cppmfix.cpp.o):/usr/include/boost/asio/error.hpp:216: more undefined references to boost::system::system_category()' follow model/cppmfix/libcppmfix.a(cppmfix.cpp.o): In function __static_initialization_and_destruction_0’:
/usr/include/boost/system/error_code.hpp:214: undefined reference to boost::system::generic_category()' /usr/include/boost/system/error_code.hpp:215: undefined reference to boost::system::generic_category()’
/usr/include/boost/system/error_code.hpp:216: undefined reference to boost::system::system_category()' model/cppmfix/libcppmfix.a(cppmfix.cpp.o): In function get_system_category’:
/usr/include/boost/asio/error.hpp:216: undefined reference to `boost::system::system_category()’
