Hi, I am trying to install mfix-20.1.2 but the following error occured.
I found some similar questions here but even after I refreshed the page I couldn’t fix it.
C:\Users\Soohwan>conda create -n mfix-20.1.2 mfix=20.1.2 mfix-doc=20.1.2 mfix-gui=20.1.2 mfix-solver=20.1.2 mfix-src=20.1.2 -c https://mfix.netl.doe.gov/s3/83a029b6/84410c63830e338913fe4287d097c5e9/conda/dist
File "C:\Users\Soohwan\anaconda3\lib\site-packages\conda\exceptions.py", line 1079, in __call__
return func(*args, **kwargs)
File "C:\Users\Soohwan\anaconda3\lib\site-packages\conda\cli\main.py", line 84, in _main
exit_code = do_call(args, p)
File "C:\Users\Soohwan\anaconda3\lib\site-packages\conda\cli\conda_argparse.py", line 82, in do_call
return getattr(module, func_name)(args, parser)
File "C:\Users\Soohwan\anaconda3\lib\site-packages\conda\cli\main_create.py", line 37, in execute
install(args, parser, 'create')
File "C:\Users\Soohwan\anaconda3\lib\site-packages\conda\cli\install.py", line 265, in install
should_retry_solve=(_should_retry_unfrozen or repodata_fn != repodata_fns[-1]),
File "C:\Users\Soohwan\anaconda3\lib\site-packages\conda\core\solve.py", line 117, in solve_for_transaction
should_retry_solve)
File "C:\Users\Soohwan\anaconda3\lib\site-packages\conda\core\solve.py", line 158, in solve_for_diff
force_remove, should_retry_solve)
File "C:\Users\Soohwan\anaconda3\lib\site-packages\conda\core\solve.py", line 262, in solve_final_state
ssc = self._collect_all_metadata(ssc)
File "C:\Users\Soohwan\anaconda3\lib\site-packages\conda\common\io.py", line 88, in decorated
return f(*args, **kwds)
File "C:\Users\Soohwan\anaconda3\lib\site-packages\conda\core\solve.py", line 415, in _collect_all_metadata
index, r = self._prepare(prepared_specs)
File "C:\Users\Soohwan\anaconda3\lib\site-packages\conda\core\solve.py", line 1011, in _prepare
self.subdirs, prepared_specs, self._repodata_fn)
File "C:\Users\Soohwan\anaconda3\lib\site-packages\conda\core\index.py", line 228, in get_reduced_index
repodata_fn=repodata_fn)
File "C:\Users\Soohwan\anaconda3\lib\site-packages\conda\core\subdir_data.py", line 105, in query_all
result = tuple(concat(executor.map(subdir_query, channel_urls)))
File "C:\Users\Soohwan\anaconda3\lib\concurrent\futures\_base.py", line 598, in result_iterator
yield fs.pop().result()
File "C:\Users\Soohwan\anaconda3\lib\concurrent\futures\_base.py", line 435, in result
return self.__get_result()
File "C:\Users\Soohwan\anaconda3\lib\concurrent\futures\_base.py", line 384, in __get_result
raise self._exception
File "C:\Users\Soohwan\anaconda3\lib\concurrent\futures\thread.py", line 57, in run
result = self.fn(*self.args, **self.kwargs)
File "C:\Users\Soohwan\anaconda3\lib\site-packages\conda\core\subdir_data.py", line 98, in <lambda>
package_ref_or_match_spec))
File "C:\Users\Soohwan\anaconda3\lib\site-packages\conda\core\subdir_data.py", line 110, in query
self.load()
File "C:\Users\Soohwan\anaconda3\lib\site-packages\conda\core\subdir_data.py", line 174, in load
_internal_state = self._load()
File "C:\Users\Soohwan\anaconda3\lib\site-packages\conda\core\subdir_data.py", line 248, in _load
repodata_fn=self.repodata_fn)
File "C:\Users\Soohwan\anaconda3\lib\site-packages\conda\core\subdir_data.py", line 485, in fetch_repodata_remote_request
timeout=timeout)
File "C:\Users\Soohwan\anaconda3\lib\site-packages\requests\sessions.py", line 546, in get
return self.request('GET', url, **kwargs)
File "C:\Users\Soohwan\anaconda3\lib\site-packages\requests\sessions.py", line 524, in request
prep.url, proxies, stream, verify, cert
File "C:\Users\Soohwan\anaconda3\lib\site-packages\requests\sessions.py", line 700, in merge_environment_settings
env_proxies = get_environ_proxies(url, no_proxy=no_proxy)
File "C:\Users\Soohwan\anaconda3\lib\site-packages\requests\utils.py", line 761, in get_environ_proxies
if should_bypass_proxies(url, no_proxy=no_proxy):
File "C:\Users\Soohwan\anaconda3\lib\site-packages\conda\gateways\connection\__init__.py", line 12, in should_bypass_proxies_patched
return should_bypass_proxies_func(url, no_proxy)
File "C:\Users\Soohwan\anaconda3\lib\site-packages\requests\utils.py", line 745, in should_bypass_proxies
bypass = proxy_bypass(parsed.hostname)
File "C:\Users\Soohwan\anaconda3\lib\site-packages\requests\utils.py", line 95, in proxy_bypass
return proxy_bypass_registry(host)
File "C:\Users\Soohwan\anaconda3\lib\site-packages\requests\utils.py", line 61, in proxy_bypass_registry
'ProxyEnable')[0])
ValueError: invalid literal for int() with base 10: b'\x00\x00\x00\x00'
$ C:\Users\Soohwan\anaconda3\Scripts\conda-script.py create -n mfix-20.1.2 mfix=20.1.2 mfix-doc=20.1.2 mfix-gui=20.1.2 mfix-solver=20.1.2 mfix-src=20.1.2 -c https://mfix.netl.doe.gov/s3/83a029b6/84410c63830e338913fe4287d097c5e9/conda/dist
environment variables:
CIO_TEST=
CONDA_DEFAULT_ENV=base
CONDA_EXE=C:\Users\Soohwan\anaconda3\condabin..\Scripts\conda.exe
CONDA_EXES=“C:\Users\Soohwan\anaconda3\condabin..\Scripts\conda.exe”
CONDA_PREFIX=C:\Users\Soohwan\anaconda3
CONDA_PROMPT_MODIFIER=(base)
CONDA_PYTHON_EXE=C:\Users\Soohwan\anaconda3\python.exe
CONDA_ROOT=C:\Users\Soohwan\anaconda3
CONDA_SHLVL=1
HOMEPATH=\Users\Soohwan
PATH=C:\Users\Soohwan\anaconda3;C:\Users\Soohwan\anaconda3\Library\mingw-w6
4\bin;C:\Users\Soohwan\anaconda3\Library\usr\bin;C:\Users\Soohwan\anac
onda3\Library\bin;C:\Users\Soohwan\anaconda3\Scripts;C:\Users\Soohwan
anaconda3\bin;C:\Users\Soohwan\anaconda3;C:\Users\Soohwan\anaconda3\Li
brary\mingw-w64\bin;C:\Users\Soohwan\anaconda3\Library\usr\bin;C:\User
s\Soohwan\anaconda3\Library\bin;C:\Users\Soohwan\anaconda3\Scripts;C:
Users\Soohwan\anaconda3\bin;C:\Users\Soohwan\anaconda3\condabin;C:\Pro
gram Files (x86)\Common Files\Oracle\Java\javapath;C:\Program Files
(x86)\Intel\iCLS Client;C:\Program Files\Intel\iCLS Client;C:\WINDOWS
system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\Windo
wsPowerShell\v1.0;C:\Program Files (x86)\Intel\Intel(R) Management
Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management
Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management
Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management
Engine Components\IPT;C:\Program Files\Intel\WiFi\bin;C:\Program
Files\Common Files\Intel\WirelessCommon;C:\Program
Files\MATLAB\R2018a\bin;C:\WINDOWS\System32\OpenSSH;C:\Program
Files\Microsoft SQL Server\110\Tools\Binn;C:\Program Files
(x86)\Common Files\AspenTech Shared;C:\Program
Files\Git\cmd;c:\Program Files (x86)\Microsoft SQL
Server\100\Tools\Binn;c:\Program Files\Microsoft SQL
Server\100\Tools\Binn;c:\Program Files\Microsoft SQL Server\100\DTS\Bi
nn;C:\Users\Soohwan\AppData\Local\Microsoft\WindowsApps;.;C:\TDM-
GCC-64\bin
PSMODULEPATH=C:\Program Files\WindowsPowerShell\Modules;C:\WINDOWS\system32\Windows
PowerShell\v1.0\Modules
REQUESTS_CA_BUNDLE=
SSL_CERT_FILE=
active environment : base
active env location : C:\Users\Soohwan\anaconda3
shell level : 1
user config file : C:\Users\Soohwan\.condarc
populated config files : C:\Users\Soohwan.condarc
conda version : 4.8.2
conda-build version : 3.18.11
python version : 3.7.6.final.0
virtual packages :
base environment : C:\Users\Soohwan\anaconda3 (writable)
channel URLs : https://mfix.netl.doe.gov/s3/83a029b6/84410c63830e338913fe4287d097c5e9/conda/dist/win-64
https://mfix.netl.doe.gov/s3/83a029b6/84410c63830e338913fe4287d097c5e9/conda/dist/noarch
main/win-64
main/noarch
r/win-64
r/noarch
msys2/win-64
msys2/noarch
package cache : C:\Users\Soohwan\anaconda3\pkgs
C:\Users\Soohwan.conda\pkgs
C:\Users\Soohwan\AppData\Local\conda\conda\pkgs
envs directories : C:\Users\Soohwan\anaconda3\envs
C:\Users\Soohwan.conda\envs
C:\Users\Soohwan\AppData\Local\conda\conda\envs
platform : win-64
user-agent : conda/4.8.2 requests/2.22.0 CPython/3.7.6 Windows/10 Windows/10.0.18362
administrator : False
netrc file : None
offline mode : False
