I downloaded version 22.4.1. Thank you very much for updating the bug issues.
Also, I was wondering if you provide your invaluable insights in following. I am trying to run simulation in carya cluster. For this I am trying first to run in my local computer (terminal ) and then cluster. I followed the following steps:
Then, I tried to run the solver following ‘6.1.2.’ from ‘6.1. Default Interactive Solver — MFiX 20.3.1 documentation’ for silane_pyrolysis_tfm_2d.mfx. But when I ran ‘mfixsolver -f silane_pyrolysis_tfm_2d.mfx’. It gave ‘zsh: command not found: mfixsolver’*
I would be grateful if you could help me understand it.
Thank you very much.
Hi @cgw,
Thank you very much for your suggestion. I am trying to learn to run MFiX to run from command line so that running it in cluster becomes easier.
As per your suggestion, I tried running ‘./mfixsolver -f silane_pyrolosis_tfm_2d.mfx’ and I got the following output.
Error 1000: Input data file does not exist: silane_pyrolosis_tfm_2d.mfx
Aborting.
*** The MPI_Comm_f2c() function was called before MPI_INIT was invoked.
*** This is disallowed by the MPI standard.
*** Your MPI job will now abort.
[Alenas-iMac.local:71095] Local abort before MPI_INIT completed completed successfully, but am not able to aggregate error messages, and not able to guarantee that all other processes were killed!
optimusprime@Alenas-iMac silane_pyrolysis_2d %.
Hi @cgw,
Sorry for my mistake with the name. I ran it with correcting the name and I got the following.
optimusprime@Alenas-iMac silane_pyrolysis_2d % ./mfixsolver -f silane_pyrolysis_tfm_2d.mfx
Error 2000: Unable to process line 874 of the project file.
A1F = 1.0800E+13
Possible causes are
Incorrect or illegal keyword format
Unknown or mistyped name
The dimensioned item is too small (array overflow).
Please see the user documentation for this keyword.
This ‘Unknown keyword’ error results from using the default (pre-built) mfixsolver to run a case with extra keywords defined in UDFs (user-defined functions, i.e. Fortran files in the project directory)
The solver must be rebuilt (custom solver) to be able to handle these additional keywords, or else you will see the ‘Unknown keyword’ error.
I just tried this with the 22.4.1 release on a Mac (I see you are on a Mac) and it works fine whether I build the interactive solver:
mfix-22.4.1:) build_mfixsolver -j
or the batch solver:
mfix-22.4.1:) build_mfixsolver --batch -j
Either way results in a mfixsolver that is able to handle silane_pyrolysis_tfm_2d.mfx without resulting in an Unknown keyword error.
Note, if the cluster you are going to run this on is not a Mac cluster you will have to log in to the cluster and build the solver there! You may need to get some help from local experts.
Thank you very much. I can now run MFiX from command line with help your information and guidance from my supervisor.
My ultimate aim is to run models in the carya cluster (building, running and visualizing). So, I am now trying develop DEM models without using GUI with terminal. Could you please guide me to learn about .stl, .mfx, .f, etc? or Could you suggest me some book or literature?
Perhaps your supervisor has some literature recommendations. We have somewhat limited resources for user support at this time.
Here are a few quick answers:
.stl is a standard file format used for 3D models. It is a very simple format. Here’s a nice explanation on the Adobe web site: STL files explained
.mfx files are only used by MFiX. They contain the MFiX keywords. The GUI makes it so that you generally don’t have to compose this file yourself. The reference for mfx files is the reference for MFiX itself: Keyword reference
.f files are Fortran source code. If you have no experience with Fortran, I recoomend the book " Modern Fortran - but there are numerous other books on the topic.
If you have further questions, please create a new topic with an appropriate title, rather than tacking on to release announcements etc.
Thank you for the excellent work. I want to make a suggestion that could the new version add the monitoring function of chemical reaction heat. I’m looking forward to this function. Although I tried to change the code to implement this function before, I always felt that the value monitored was incorrect.
