[quote=“cgw, post:4, topic:5337”]
This issue really has nothing to do with MFiX. If you can’t run glxgears and glxinfo then something is wrong. We cannot help you fix this but I can offer some advice: I see that DISPLAY is set to localhost:89.0
which means you are doing some sort of remote display - this usually requires vglrun but as we have seen that does not help. Have you pursued the Permission denied problem reported on /run/user/xxx ? Can you run X11 programs that don’t use OpenGL, like xterm?
I got glxgears and xterm to open. glxinfo now run with the following:
glxinfo
name of display: localhost:55.0
libGL error: No matching fbConfigs or visuals found
libGL error: failed to load driver: swrast
display: localhost:55 screen: 0
direct rendering: No (If you want to find out why, try setting LIBGL_DEBUG=verbose)
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
GLX_ARB_multisample, GLX_EXT_get_drawable_type, GLX_EXT_import_context,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_OML_swap_method,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_SGI_make_current_read
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_context_flush_control, GLX_ARB_create_context,
GLX_ARB_create_context_no_error, GLX_ARB_create_context_profile,
GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
GLX_ARB_framebuffer_sRGB, GLX_ARB_get_proc_address, GLX_ARB_multisample,
GLX_ATI_pixel_format_float, GLX_EXT_buffer_age,
GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
GLX_EXT_import_context, GLX_EXT_no_config_context, GLX_EXT_swap_control,
GLX_EXT_swap_control_tear, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_INTEL_swap_event,
GLX_MESA_copy_sub_buffer, GLX_MESA_query_renderer, GLX_MESA_swap_control,
GLX_NV_float_buffer, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGIX_visual_select_group, GLX_SGI_make_current_read,
GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
OpenGL vendor string: ATI Technologies Inc.
OpenGL renderer string: AMD Radeon Pro 5300M OpenGL Engine
OpenGL version string: 1.4 (2.1 ATI-4.14.1)
OpenGL extensions:
144 GLX Visuals
visual x bf lv rg d st colorbuffer sr ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a F gb bf th cl r g b a ns b eat
0x022 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 8 0 0 0 0 0 0 None
0x140 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 Slow
0x141 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 16 1 Slow
0x142 24 tc 0 32 0 r . . 8 8 8 8 . . 0 32 0 0 0 0 0 0 0 Slow
0x143 24 tc 0 32 0 r . . 8 8 8 8 . . 0 32 0 0 0 0 0 16 1 Slow
0x144 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 Slow
0x145 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 8 0 0 0 0 16 1 Slow
0x146 24 tc 0 32 0 r . . 8 8 8 8 . . 0 32 8 0 0 0 0 0 0 Slow
0x147 24 tc 0 32 0 r . . 8 8 8 8 . . 0 32 8 0 0 0 0 16 1 Slow
0x148 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 Slow
0x149 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 16 1 Slow
0x14a 24 tc 0 32 0 r y . 8 8 8 8 . . 0 32 0 0 0 0 0 0 0 Slow
0x14b 24 tc 0 32 0 r y . 8 8 8 8 . . 0 32 0 0 0 0 0 16 1 Slow
0x14c 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 Slow
0x14d 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 8 0 0 0 0 16 1 Slow
0x14e 24 tc 0 32 0 r y . 8 8 8 8 . . 0 32 8 0 0 0 0 0 0 Slow
0x14f 24 tc 0 32 0 r y . 8 8 8 8 . . 0 32 8 0 0 0 0 16 1 Slow
0x150 24 tc 0 32 0 r . . 8 8 8 8 . . 4 0 0 0 0 0 0 0 0 Slow
0x151 24 tc 0 32 0 r . . 8 8 8 8 . . 4 0 0 0 0 0 0 16 1 Slow
0x152 24 tc 0 32 0 r . . 8 8 8 8 . . 4 32 0 0 0 0 0 0 0 Slow
0x153 24 tc 0 32 0 r . . 8 8 8 8 . . 4 32 0 0 0 0 0 16 1 Slow
0x154 24 tc 0 32 0 r . . 8 8 8 8 . . 4 0 8 0 0 0 0 0 0 Slow
0x155 24 tc 0 32 0 r . . 8 8 8 8 . . 4 0 8 0 0 0 0 16 1 Slow
0x156 24 tc 0 32 0 r . . 8 8 8 8 . . 4 32 8 0 0 0 0 0 0 Slow
0x157 24 tc 0 32 0 r . . 8 8 8 8 . . 4 32 8 0 0 0 0 16 1 Slow
0x158 24 tc 0 32 0 r y . 8 8 8 8 . . 4 0 0 0 0 0 0 0 0 Slow
0x159 24 tc 0 32 0 r y . 8 8 8 8 . . 4 0 0 0 0 0 0 16 1 Slow
0x15a 24 tc 0 32 0 r y . 8 8 8 8 . . 4 32 0 0 0 0 0 0 0 Slow
0x15b 24 tc 0 32 0 r y . 8 8 8 8 . . 4 32 0 0 0 0 0 16 1 Slow
0x15c 24 tc 0 32 0 r y . 8 8 8 8 . . 4 0 8 0 0 0 0 0 0 Slow
0x15d 24 tc 0 32 0 r y . 8 8 8 8 . . 4 0 8 0 0 0 0 16 1 Slow
0x15e 24 tc 0 32 0 r y . 8 8 8 8 . . 4 32 8 0 0 0 0 0 0 Slow
0x15f 24 tc 0 32 0 r y . 8 8 8 8 . . 4 32 8 0 0 0 0 16 1 Slow
0x160 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x161 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 8 1 None
0x162 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x163 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 8 1 None
0x164 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x165 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 8 1 None
0x166 24 tc 0 32 0 r . . 8 8 8 8 . . 0 32 0 0 0 0 0 0 0 None
0x167 24 tc 0 32 0 r . . 8 8 8 8 . . 0 32 0 0 0 0 0 8 1 None
0x168 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 None
0x169 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 8 0 0 0 0 8 1 None
0x16a 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 8 0 0 0 0 0 0 None
0x16b 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 8 0 0 0 0 8 1 None
0x16c 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x16d 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 8 1 None
0x16e 24 tc 0 32 0 r . . 8 8 8 8 . . 0 32 8 0 0 0 0 0 0 None
0x16f 24 tc 0 32 0 r . . 8 8 8 8 . . 0 32 8 0 0 0 0 8 1 None
0x170 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x171 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 8 1 None
0x172 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x173 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 8 1 None
0x174 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x175 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 8 1 None
0x176 24 tc 0 32 0 r y . 8 8 8 8 . . 0 32 0 0 0 0 0 0 0 None
0x177 24 tc 0 32 0 r y . 8 8 8 8 . . 0 32 0 0 0 0 0 8 1 None
0x178 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 None
0x179 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 8 0 0 0 0 8 1 None
0x17a 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 8 0 0 0 0 8 1 None
0x17b 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x17c 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 8 1 None
0x17d 24 tc 0 32 0 r y . 8 8 8 8 . . 0 32 8 0 0 0 0 0 0 None
0x17e 24 tc 0 32 0 r y . 8 8 8 8 . . 0 32 8 0 0 0 0 8 1 None
0x17f 24 tc 0 32 0 r . . 8 8 8 8 . . 2 0 0 0 0 0 0 0 0 None
0x180 24 tc 0 32 0 r . . 8 8 8 8 . . 2 0 0 0 0 0 0 8 1 None
0x181 24 tc 0 32 0 r . . 8 8 8 8 . . 2 16 0 0 0 0 0 0 0 None
0x182 24 tc 0 32 0 r . . 8 8 8 8 . . 2 16 0 0 0 0 0 8 1 None
0x183 24 tc 0 32 0 r . . 8 8 8 8 . . 2 24 0 0 0 0 0 0 0 None
0x184 24 tc 0 32 0 r . . 8 8 8 8 . . 2 24 0 0 0 0 0 8 1 None
0x185 24 tc 0 32 0 r . . 8 8 8 8 . . 2 32 0 0 0 0 0 0 0 None
0x186 24 tc 0 32 0 r . . 8 8 8 8 . . 2 32 0 0 0 0 0 8 1 None
0x187 24 tc 0 32 0 r . . 8 8 8 8 . . 2 0 8 0 0 0 0 0 0 None
0x188 24 tc 0 32 0 r . . 8 8 8 8 . . 2 0 8 0 0 0 0 8 1 None
0x189 24 tc 0 32 0 r . . 8 8 8 8 . . 2 16 8 0 0 0 0 0 0 None
0x18a 24 tc 0 32 0 r . . 8 8 8 8 . . 2 16 8 0 0 0 0 8 1 None
0x18b 24 tc 0 32 0 r . . 8 8 8 8 . . 2 24 8 0 0 0 0 0 0 None
0x18c 24 tc 0 32 0 r . . 8 8 8 8 . . 2 24 8 0 0 0 0 8 1 None
0x18d 24 tc 0 32 0 r . . 8 8 8 8 . . 2 32 8 0 0 0 0 0 0 None
0x18e 24 tc 0 32 0 r . . 8 8 8 8 . . 2 32 8 0 0 0 0 8 1 None
0x18f 24 tc 0 32 0 r y . 8 8 8 8 . . 2 0 0 0 0 0 0 0 0 None
0x190 24 tc 0 32 0 r y . 8 8 8 8 . . 2 0 0 0 0 0 0 8 1 None
0x191 24 tc 0 32 0 r y . 8 8 8 8 . . 2 16 0 0 0 0 0 0 0 None
0x192 24 tc 0 32 0 r y . 8 8 8 8 . . 2 16 0 0 0 0 0 8 1 None
0x193 24 tc 0 32 0 r y . 8 8 8 8 . . 2 24 0 0 0 0 0 0 0 None
0x194 24 tc 0 32 0 r y . 8 8 8 8 . . 2 24 0 0 0 0 0 8 1 None
0x195 24 tc 0 32 0 r y . 8 8 8 8 . . 2 32 0 0 0 0 0 0 0 None
0x196 24 tc 0 32 0 r y . 8 8 8 8 . . 2 32 0 0 0 0 0 8 1 None
0x197 24 tc 0 32 0 r y . 8 8 8 8 . . 2 0 8 0 0 0 0 0 0 None
0x198 24 tc 0 32 0 r y . 8 8 8 8 . . 2 0 8 0 0 0 0 8 1 None
0x199 24 tc 0 32 0 r y . 8 8 8 8 . . 2 16 8 0 0 0 0 0 0 None
0x19a 24 tc 0 32 0 r y . 8 8 8 8 . . 2 16 8 0 0 0 0 8 1 None
0x19b 24 tc 0 32 0 r y . 8 8 8 8 . . 2 24 8 0 0 0 0 0 0 None
0x19c 24 tc 0 32 0 r y . 8 8 8 8 . . 2 24 8 0 0 0 0 8 1 None
0x19d 24 tc 0 32 0 r y . 8 8 8 8 . . 2 32 8 0 0 0 0 0 0 None
0x19e 24 tc 0 32 0 r y . 8 8 8 8 . . 2 32 8 0 0 0 0 8 1 None
0x19f 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x1a0 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 16 1 None
0x1a1 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x1a2 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 16 1 None
0x1a3 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x1a4 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 16 1 None
0x1a5 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 None
0x1a6 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 8 0 0 0 0 16 1 None
0x1a7 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 8 0 0 0 0 0 0 None
0x1a8 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 8 0 0 0 0 16 1 None
0x1a9 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x1aa 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 16 1 None
0x1ab 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x1ac 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 16 1 None
0x1ad 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x1ae 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 16 1 None
0x1af 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x1b0 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 16 1 None
0x1b1 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 None
0x1b2 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 8 0 0 0 0 16 1 None
0x1b3 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 8 0 0 0 0 0 0 None
0x1b4 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 8 0 0 0 0 16 1 None
0x1b5 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x1b6 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 16 1 None
0x1b7 24 tc 0 32 0 r . . 8 8 8 8 . . 2 0 0 0 0 0 0 0 0 None
0x1b8 24 tc 0 32 0 r . . 8 8 8 8 . . 2 0 0 0 0 0 0 16 1 None
0x1b9 24 tc 0 32 0 r . . 8 8 8 8 . . 2 16 0 0 0 0 0 0 0 None
0x1ba 24 tc 0 32 0 r . . 8 8 8 8 . . 2 16 0 0 0 0 0 16 1 None
0x1bb 24 tc 0 32 0 r . . 8 8 8 8 . . 2 24 0 0 0 0 0 0 0 None
0x1bc 24 tc 0 32 0 r . . 8 8 8 8 . . 2 24 0 0 0 0 0 16 1 None
0x1bd 24 tc 0 32 0 r . . 8 8 8 8 . . 2 0 8 0 0 0 0 0 0 None
0x1be 24 tc 0 32 0 r . . 8 8 8 8 . . 2 0 8 0 0 0 0 16 1 None
0x1bf 24 tc 0 32 0 r . . 8 8 8 8 . . 2 16 8 0 0 0 0 0 0 None
0x1c0 24 tc 0 32 0 r . . 8 8 8 8 . . 2 16 8 0 0 0 0 16 1 None
0x1c1 24 tc 0 32 0 r . . 8 8 8 8 . . 2 24 8 0 0 0 0 0 0 None
0x1c2 24 tc 0 32 0 r . . 8 8 8 8 . . 2 24 8 0 0 0 0 16 1 None
0x1c3 24 tc 0 32 0 r y . 8 8 8 8 . . 2 0 0 0 0 0 0 0 0 None
0x1c4 24 tc 0 32 0 r y . 8 8 8 8 . . 2 0 0 0 0 0 0 16 1 None
0x1c5 24 tc 0 32 0 r y . 8 8 8 8 . . 2 16 0 0 0 0 0 0 0 None
0x1c6 24 tc 0 32 0 r y . 8 8 8 8 . . 2 16 0 0 0 0 0 16 1 None
0x1c7 24 tc 0 32 0 r y . 8 8 8 8 . . 2 24 0 0 0 0 0 0 0 None
0x1c8 24 tc 0 32 0 r y . 8 8 8 8 . . 2 24 0 0 0 0 0 16 1 None
0x1c9 24 tc 0 32 0 r y . 8 8 8 8 . . 2 0 8 0 0 0 0 0 0 None
0x1ca 24 tc 0 32 0 r y . 8 8 8 8 . . 2 0 8 0 0 0 0 16 1 None
0x1cb 24 tc 0 32 0 r y . 8 8 8 8 . . 2 16 8 0 0 0 0 0 0 None
0x1cc 24 tc 0 32 0 r y . 8 8 8 8 . . 2 16 8 0 0 0 0 16 1 None
0x1cd 24 tc 0 32 0 r y . 8 8 8 8 . . 2 24 8 0 0 0 0 0 0 None
0x1ce 24 tc 0 32 0 r y . 8 8 8 8 . . 2 24 8 0 0 0 0 16 1 None
256 GLXFBConfigs:
0x040 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 Slow
0x041 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 16 1 Slow
0x042 24 tc 0 32 0 r . . 8 8 8 8 . . 0 32 0 0 0 0 0 0 0 Slow
0x043 24 tc 0 32 0 r . . 8 8 8 8 . . 0 32 0 0 0 0 0 16 1 Slow
0x044 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 Slow
0x045 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 8 0 0 0 0 16 1 Slow
0x046 24 tc 0 32 0 r . . 8 8 8 8 . . 0 32 8 0 0 0 0 0 0 Slow
0x047 24 tc 0 32 0 r . . 8 8 8 8 . . 0 32 8 0 0 0 0 16 1 Slow
0x048 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 Slow
0x049 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 16 1 Slow
0x04a 24 tc 0 32 0 r y . 8 8 8 8 . . 0 32 0 0 0 0 0 0 0 Slow
0x04b 24 tc 0 32 0 r y . 8 8 8 8 . . 0 32 0 0 0 0 0 16 1 Slow
0x04c 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 Slow
0x04d 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 8 0 0 0 0 16 1 Slow
0x04e 24 tc 0 32 0 r y . 8 8 8 8 . . 0 32 8 0 0 0 0 0 0 Slow
0x04f 24 tc 0 32 0 r y . 8 8 8 8 . . 0 32 8 0 0 0 0 16 1 Slow
0x050 24 tc 0 32 0 r . . 8 8 8 8 . . 4 0 0 0 0 0 0 0 0 Slow
0x051 24 tc 0 32 0 r . . 8 8 8 8 . . 4 0 0 0 0 0 0 16 1 Slow
0x052 24 tc 0 32 0 r . . 8 8 8 8 . . 4 32 0 0 0 0 0 0 0 Slow
0x053 24 tc 0 32 0 r . . 8 8 8 8 . . 4 32 0 0 0 0 0 16 1 Slow
0x054 24 tc 0 32 0 r . . 8 8 8 8 . . 4 0 8 0 0 0 0 0 0 Slow
0x055 24 tc 0 32 0 r . . 8 8 8 8 . . 4 0 8 0 0 0 0 16 1 Slow
0x056 24 tc 0 32 0 r . . 8 8 8 8 . . 4 32 8 0 0 0 0 0 0 Slow
0x057 24 tc 0 32 0 r . . 8 8 8 8 . . 4 32 8 0 0 0 0 16 1 Slow
0x058 24 tc 0 32 0 r y . 8 8 8 8 . . 4 0 0 0 0 0 0 0 0 Slow
0x059 24 tc 0 32 0 r y . 8 8 8 8 . . 4 0 0 0 0 0 0 16 1 Slow
0x05a 24 tc 0 32 0 r y . 8 8 8 8 . . 4 32 0 0 0 0 0 0 0 Slow
0x05b 24 tc 0 32 0 r y . 8 8 8 8 . . 4 32 0 0 0 0 0 16 1 Slow
0x05c 24 tc 0 32 0 r y . 8 8 8 8 . . 4 0 8 0 0 0 0 0 0 Slow
0x05d 24 tc 0 32 0 r y . 8 8 8 8 . . 4 0 8 0 0 0 0 16 1 Slow
0x05e 24 tc 0 32 0 r y . 8 8 8 8 . . 4 32 8 0 0 0 0 0 0 Slow
0x05f 24 tc 0 32 0 r y . 8 8 8 8 . . 4 32 8 0 0 0 0 16 1 Slow
0x060 0 tc 0 16 0 r . . 5 5 5 1 . . 0 0 0 0 0 0 0 0 0 None
0x061 0 tc 0 16 0 r . . 5 5 5 1 . . 0 0 0 0 0 0 0 8 1 None
0x062 0 tc 0 16 0 r . . 5 5 5 1 . . 0 16 0 0 0 0 0 0 0 None
0x063 0 tc 0 16 0 r . . 5 5 5 1 . . 0 16 0 0 0 0 0 8 1 None
0x064 0 tc 0 16 0 r . . 5 5 5 1 . . 0 24 0 0 0 0 0 0 0 None
0x065 0 tc 0 16 0 r . . 5 5 5 1 . . 0 24 0 0 0 0 0 8 1 None
0x066 0 tc 0 16 0 r . . 5 5 5 1 . . 0 32 0 0 0 0 0 0 0 None
0x067 0 tc 0 16 0 r . . 5 5 5 1 . . 0 32 0 0 0 0 0 8 1 None
0x068 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x069 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 8 1 None
0x06a 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x06b 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 8 1 None
0x06c 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x06d 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 8 1 None
0x06e 24 tc 0 32 0 r . . 8 8 8 8 . . 0 32 0 0 0 0 0 0 0 None
0x06f 24 tc 0 32 0 r . . 8 8 8 8 . . 0 32 0 0 0 0 0 8 1 None
0x070 0 tc 0 16 0 r . . 5 5 5 1 . . 0 0 8 0 0 0 0 0 0 None
0x071 0 tc 0 16 0 r . . 5 5 5 1 . . 0 0 8 0 0 0 0 8 1 None
0x072 0 tc 0 16 0 r . . 5 5 5 1 . . 0 16 8 0 0 0 0 0 0 None
0x073 0 tc 0 16 0 r . . 5 5 5 1 . . 0 16 8 0 0 0 0 8 1 None
0x074 0 tc 0 16 0 r . . 5 5 5 1 . . 0 24 8 0 0 0 0 0 0 None
0x075 0 tc 0 16 0 r . . 5 5 5 1 . . 0 24 8 0 0 0 0 8 1 None
0x076 0 tc 0 16 0 r . . 5 5 5 1 . . 0 32 8 0 0 0 0 0 0 None
0x077 0 tc 0 16 0 r . . 5 5 5 1 . . 0 32 8 0 0 0 0 8 1 None
0x078 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 None
0x079 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 8 0 0 0 0 8 1 None
0x07a 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 8 0 0 0 0 0 0 None
0x07b 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 8 0 0 0 0 8 1 None
0x07c 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x07d 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 8 1 None
0x07e 24 tc 0 32 0 r . . 8 8 8 8 . . 0 32 8 0 0 0 0 0 0 None
0x07f 24 tc 0 32 0 r . . 8 8 8 8 . . 0 32 8 0 0 0 0 8 1 None
0x080 0 tc 0 16 0 r y . 5 5 5 1 . . 0 0 0 0 0 0 0 0 0 None
0x081 0 tc 0 16 0 r y . 5 5 5 1 . . 0 0 0 0 0 0 0 8 1 None
0x082 0 tc 0 16 0 r y . 5 5 5 1 . . 0 16 0 0 0 0 0 0 0 None
0x083 0 tc 0 16 0 r y . 5 5 5 1 . . 0 16 0 0 0 0 0 8 1 None
0x084 0 tc 0 16 0 r y . 5 5 5 1 . . 0 24 0 0 0 0 0 0 0 None
0x085 0 tc 0 16 0 r y . 5 5 5 1 . . 0 24 0 0 0 0 0 8 1 None
0x086 0 tc 0 16 0 r y . 5 5 5 1 . . 0 32 0 0 0 0 0 0 0 None
0x087 0 tc 0 16 0 r y . 5 5 5 1 . . 0 32 0 0 0 0 0 8 1 None
0x088 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x089 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 8 1 None
0x08a 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x08b 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 8 1 None
0x08c 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x08d 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 8 1 None
0x08e 24 tc 0 32 0 r y . 8 8 8 8 . . 0 32 0 0 0 0 0 0 0 None
0x08f 24 tc 0 32 0 r y . 8 8 8 8 . . 0 32 0 0 0 0 0 8 1 None
0x090 0 tc 0 16 0 r y . 5 5 5 1 . . 0 0 8 0 0 0 0 0 0 None
0x091 0 tc 0 16 0 r y . 5 5 5 1 . . 0 0 8 0 0 0 0 8 1 None
0x092 0 tc 0 16 0 r y . 5 5 5 1 . . 0 16 8 0 0 0 0 0 0 None
0x093 0 tc 0 16 0 r y . 5 5 5 1 . . 0 16 8 0 0 0 0 8 1 None
0x094 0 tc 0 16 0 r y . 5 5 5 1 . . 0 24 8 0 0 0 0 0 0 None
0x095 0 tc 0 16 0 r y . 5 5 5 1 . . 0 24 8 0 0 0 0 8 1 None
0x096 0 tc 0 16 0 r y . 5 5 5 1 . . 0 32 8 0 0 0 0 0 0 None
0x097 0 tc 0 16 0 r y . 5 5 5 1 . . 0 32 8 0 0 0 0 8 1 None
0x098 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 None
0x099 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 8 0 0 0 0 8 1 None
0x09a 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 8 0 0 0 0 0 0 None
0x09b 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 8 0 0 0 0 8 1 None
0x09c 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x09d 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 8 1 None
0x09e 24 tc 0 32 0 r y . 8 8 8 8 . . 0 32 8 0 0 0 0 0 0 None
0x09f 24 tc 0 32 0 r y . 8 8 8 8 . . 0 32 8 0 0 0 0 8 1 None
0x0a0 0 tc 0 16 0 r . . 5 5 5 1 . . 2 0 0 0 0 0 0 0 0 None
0x0a1 0 tc 0 16 0 r . . 5 5 5 1 . . 2 0 0 0 0 0 0 8 1 None
0x0a2 0 tc 0 16 0 r . . 5 5 5 1 . . 2 16 0 0 0 0 0 0 0 None
0x0a3 0 tc 0 16 0 r . . 5 5 5 1 . . 2 16 0 0 0 0 0 8 1 None
0x0a4 0 tc 0 16 0 r . . 5 5 5 1 . . 2 24 0 0 0 0 0 0 0 None
0x0a5 0 tc 0 16 0 r . . 5 5 5 1 . . 2 24 0 0 0 0 0 8 1 None
0x0a6 0 tc 0 16 0 r . . 5 5 5 1 . . 2 32 0 0 0 0 0 0 0 None
0x0a7 0 tc 0 16 0 r . . 5 5 5 1 . . 2 32 0 0 0 0 0 8 1 None
0x0a8 24 tc 0 32 0 r . . 8 8 8 8 . . 2 0 0 0 0 0 0 0 0 None
0x0a9 24 tc 0 32 0 r . . 8 8 8 8 . . 2 0 0 0 0 0 0 8 1 None
0x0aa 24 tc 0 32 0 r . . 8 8 8 8 . . 2 16 0 0 0 0 0 0 0 None
0x0ab 24 tc 0 32 0 r . . 8 8 8 8 . . 2 16 0 0 0 0 0 8 1 None
0x0ac 24 tc 0 32 0 r . . 8 8 8 8 . . 2 24 0 0 0 0 0 0 0 None
0x0ad 24 tc 0 32 0 r . . 8 8 8 8 . . 2 24 0 0 0 0 0 8 1 None
0x0ae 24 tc 0 32 0 r . . 8 8 8 8 . . 2 32 0 0 0 0 0 0 0 None
0x0af 24 tc 0 32 0 r . . 8 8 8 8 . . 2 32 0 0 0 0 0 8 1 None
0x0b0 0 tc 0 16 0 r . . 5 5 5 1 . . 2 0 8 0 0 0 0 0 0 None
0x0b1 0 tc 0 16 0 r . . 5 5 5 1 . . 2 0 8 0 0 0 0 8 1 None
0x0b2 0 tc 0 16 0 r . . 5 5 5 1 . . 2 16 8 0 0 0 0 0 0 None
0x0b3 0 tc 0 16 0 r . . 5 5 5 1 . . 2 16 8 0 0 0 0 8 1 None
0x0b4 0 tc 0 16 0 r . . 5 5 5 1 . . 2 24 8 0 0 0 0 0 0 None
0x0b5 0 tc 0 16 0 r . . 5 5 5 1 . . 2 24 8 0 0 0 0 8 1 None
0x0b6 0 tc 0 16 0 r . . 5 5 5 1 . . 2 32 8 0 0 0 0 0 0 None
0x0b7 0 tc 0 16 0 r . . 5 5 5 1 . . 2 32 8 0 0 0 0 8 1 None
0x0b8 24 tc 0 32 0 r . . 8 8 8 8 . . 2 0 8 0 0 0 0 0 0 None
0x0b9 24 tc 0 32 0 r . . 8 8 8 8 . . 2 0 8 0 0 0 0 8 1 None
0x0ba 24 tc 0 32 0 r . . 8 8 8 8 . . 2 16 8 0 0 0 0 0 0 None
0x0bb 24 tc 0 32 0 r . . 8 8 8 8 . . 2 16 8 0 0 0 0 8 1 None
0x0bc 24 tc 0 32 0 r . . 8 8 8 8 . . 2 24 8 0 0 0 0 0 0 None
0x0bd 24 tc 0 32 0 r . . 8 8 8 8 . . 2 24 8 0 0 0 0 8 1 None
0x0be 24 tc 0 32 0 r . . 8 8 8 8 . . 2 32 8 0 0 0 0 0 0 None
0x0bf 24 tc 0 32 0 r . . 8 8 8 8 . . 2 32 8 0 0 0 0 8 1 None
0x0c0 0 tc 0 16 0 r y . 5 5 5 1 . . 2 0 0 0 0 0 0 0 0 None
0x0c1 0 tc 0 16 0 r y . 5 5 5 1 . . 2 0 0 0 0 0 0 8 1 None
0x0c2 0 tc 0 16 0 r y . 5 5 5 1 . . 2 16 0 0 0 0 0 0 0 None
0x0c3 0 tc 0 16 0 r y . 5 5 5 1 . . 2 16 0 0 0 0 0 8 1 None
0x0c4 0 tc 0 16 0 r y . 5 5 5 1 . . 2 24 0 0 0 0 0 0 0 None
0x0c5 0 tc 0 16 0 r y . 5 5 5 1 . . 2 24 0 0 0 0 0 8 1 None
0x0c6 0 tc 0 16 0 r y . 5 5 5 1 . . 2 32 0 0 0 0 0 0 0 None
0x0c7 0 tc 0 16 0 r y . 5 5 5 1 . . 2 32 0 0 0 0 0 8 1 None
0x0c8 24 tc 0 32 0 r y . 8 8 8 8 . . 2 0 0 0 0 0 0 0 0 None
0x0c9 24 tc 0 32 0 r y . 8 8 8 8 . . 2 0 0 0 0 0 0 8 1 None
0x0ca 24 tc 0 32 0 r y . 8 8 8 8 . . 2 16 0 0 0 0 0 0 0 None
0x0cb 24 tc 0 32 0 r y . 8 8 8 8 . . 2 16 0 0 0 0 0 8 1 None
0x0cc 24 tc 0 32 0 r y . 8 8 8 8 . . 2 24 0 0 0 0 0 0 0 None
0x0cd 24 tc 0 32 0 r y . 8 8 8 8 . . 2 24 0 0 0 0 0 8 1 None
0x0ce 24 tc 0 32 0 r y . 8 8 8 8 . . 2 32 0 0 0 0 0 0 0 None
0x0cf 24 tc 0 32 0 r y . 8 8 8 8 . . 2 32 0 0 0 0 0 8 1 None
0x0d0 0 tc 0 16 0 r y . 5 5 5 1 . . 2 0 8 0 0 0 0 0 0 None
0x0d1 0 tc 0 16 0 r y . 5 5 5 1 . . 2 0 8 0 0 0 0 8 1 None
0x0d2 0 tc 0 16 0 r y . 5 5 5 1 . . 2 16 8 0 0 0 0 0 0 None
0x0d3 0 tc 0 16 0 r y . 5 5 5 1 . . 2 16 8 0 0 0 0 8 1 None
0x0d4 0 tc 0 16 0 r y . 5 5 5 1 . . 2 24 8 0 0 0 0 0 0 None
0x0d5 0 tc 0 16 0 r y . 5 5 5 1 . . 2 24 8 0 0 0 0 8 1 None
0x0d6 0 tc 0 16 0 r y . 5 5 5 1 . . 2 32 8 0 0 0 0 0 0 None
0x0d7 0 tc 0 16 0 r y . 5 5 5 1 . . 2 32 8 0 0 0 0 8 1 None
0x0d8 24 tc 0 32 0 r y . 8 8 8 8 . . 2 0 8 0 0 0 0 0 0 None
0x0d9 24 tc 0 32 0 r y . 8 8 8 8 . . 2 0 8 0 0 0 0 8 1 None
0x0da 24 tc 0 32 0 r y . 8 8 8 8 . . 2 16 8 0 0 0 0 0 0 None
0x0db 24 tc 0 32 0 r y . 8 8 8 8 . . 2 16 8 0 0 0 0 8 1 None
0x0dc 24 tc 0 32 0 r y . 8 8 8 8 . . 2 24 8 0 0 0 0 0 0 None
0x0dd 24 tc 0 32 0 r y . 8 8 8 8 . . 2 24 8 0 0 0 0 8 1 None
0x0de 24 tc 0 32 0 r y . 8 8 8 8 . . 2 32 8 0 0 0 0 0 0 None
0x0df 24 tc 0 32 0 r y . 8 8 8 8 . . 2 32 8 0 0 0 0 8 1 None
0x0e0 0 tc 0 16 0 r . . 5 5 5 1 . . 0 0 0 0 0 0 0 0 0 None
0x0e1 0 tc 0 16 0 r . . 5 5 5 1 . . 0 0 0 0 0 0 0 16 1 None
0x0e2 0 tc 0 16 0 r . . 5 5 5 1 . . 0 16 0 0 0 0 0 0 0 None
0x0e3 0 tc 0 16 0 r . . 5 5 5 1 . . 0 16 0 0 0 0 0 16 1 None
0x0e4 0 tc 0 16 0 r . . 5 5 5 1 . . 0 24 0 0 0 0 0 0 0 None
0x0e5 0 tc 0 16 0 r . . 5 5 5 1 . . 0 24 0 0 0 0 0 16 1 None
0x0e6 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x0e7 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 16 1 None
0x0e8 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x0e9 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 0 0 0 0 0 16 1 None
0x0ea 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x0eb 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 0 0 0 0 0 16 1 None
0x0ec 0 tc 0 16 0 r . . 5 5 5 1 . . 0 0 8 0 0 0 0 0 0 None
0x0ed 0 tc 0 16 0 r . . 5 5 5 1 . . 0 0 8 0 0 0 0 16 1 None
0x0ee 0 tc 0 16 0 r . . 5 5 5 1 . . 0 16 8 0 0 0 0 0 0 None
0x0ef 0 tc 0 16 0 r . . 5 5 5 1 . . 0 16 8 0 0 0 0 16 1 None
0x0f0 0 tc 0 16 0 r . . 5 5 5 1 . . 0 24 8 0 0 0 0 0 0 None
0x0f1 0 tc 0 16 0 r . . 5 5 5 1 . . 0 24 8 0 0 0 0 16 1 None
0x0f2 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 None
0x0f3 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 8 0 0 0 0 16 1 None
0x0f4 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 8 0 0 0 0 0 0 None
0x0f5 24 tc 0 32 0 r . . 8 8 8 8 . . 0 16 8 0 0 0 0 16 1 None
0x0f6 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x0f7 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 16 1 None
0x0f8 0 tc 0 16 0 r y . 5 5 5 1 . . 0 0 0 0 0 0 0 0 0 None
0x0f9 0 tc 0 16 0 r y . 5 5 5 1 . . 0 0 0 0 0 0 0 16 1 None
0x0fa 0 tc 0 16 0 r y . 5 5 5 1 . . 0 16 0 0 0 0 0 0 0 None
0x0fb 0 tc 0 16 0 r y . 5 5 5 1 . . 0 16 0 0 0 0 0 16 1 None
0x0fc 0 tc 0 16 0 r y . 5 5 5 1 . . 0 24 0 0 0 0 0 0 0 None
0x0fd 0 tc 0 16 0 r y . 5 5 5 1 . . 0 24 0 0 0 0 0 16 1 None
0x0fe 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x0ff 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 16 1 None
0x100 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 0 0 None
0x101 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 0 0 0 0 0 16 1 None
0x102 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 0 0 None
0x103 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 0 0 0 0 0 16 1 None
0x104 0 tc 0 16 0 r y . 5 5 5 1 . . 0 0 8 0 0 0 0 0 0 None
0x105 0 tc 0 16 0 r y . 5 5 5 1 . . 0 0 8 0 0 0 0 16 1 None
0x106 0 tc 0 16 0 r y . 5 5 5 1 . . 0 16 8 0 0 0 0 0 0 None
0x107 0 tc 0 16 0 r y . 5 5 5 1 . . 0 16 8 0 0 0 0 16 1 None
0x108 0 tc 0 16 0 r y . 5 5 5 1 . . 0 24 8 0 0 0 0 0 0 None
0x109 0 tc 0 16 0 r y . 5 5 5 1 . . 0 24 8 0 0 0 0 16 1 None
0x10a 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 8 0 0 0 0 0 0 None
0x10b 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 8 0 0 0 0 16 1 None
0x10c 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 8 0 0 0 0 0 0 None
0x10d 24 tc 0 32 0 r y . 8 8 8 8 . . 0 16 8 0 0 0 0 16 1 None
0x10e 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x10f 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 16 1 None
0x110 0 tc 0 16 0 r . . 5 5 5 1 . . 2 0 0 0 0 0 0 0 0 None
0x111 0 tc 0 16 0 r . . 5 5 5 1 . . 2 0 0 0 0 0 0 16 1 None
0x112 0 tc 0 16 0 r . . 5 5 5 1 . . 2 16 0 0 0 0 0 0 0 None
0x113 0 tc 0 16 0 r . . 5 5 5 1 . . 2 16 0 0 0 0 0 16 1 None
0x114 0 tc 0 16 0 r . . 5 5 5 1 . . 2 24 0 0 0 0 0 0 0 None
0x115 0 tc 0 16 0 r . . 5 5 5 1 . . 2 24 0 0 0 0 0 16 1 None
X Error of failed request: GLXBadCurrentWindow
Major opcode of failed request: 149 (GLX)
Minor opcode of failed request: 5 (X_GLXMakeCurrent)
Serial number of failed request: 54
Current serial number in output stream: 54
cgw:
If you run with the Conda packages as recommended, the VTK etc on your system are not used and updates to the system will not affect MFiX. The Conda packages include versions of VTK which we have tested and verified work.
Yes I used conda to install and activate:
(mfix-23.3.2) Wed Feb 28 me@anode
