Hello, I am a beginner and I am having some problems in using the suitable teaching tutorial, the following is my version information:
MFiX: 24.1.1
Python: 3.11.8 | packaged by conda-forge | (main, Feb 16 2024, 20:40:50) [MSC v.1937 64 bit (AMD64)]
gfortran: GNU Fortran (Rev5, Built by MSYS2 project) 5.3.0
openmpi: Unavailable
Qt wrapper: PyQt5
Qt: 5.15.8
qtpy: 2.4.1
numpy: 1.26.4
nodeworks: Unavailable
flask: 3.0.3
psutil: 5.9.8
VTK: 9.2.6
OpenGL backend: 2
System info: Windows-10-10.0.19045-SP0
Install location: D:\ProgramData\mambaforge\envs\mfix-24.1.1\share\mfix
Solver source: D:\ProgramData\mambaforge\envs\mfix-24.1.1\share\mfix\src
When I try to output video time through vtk, I get the following error:
Error: ‘CreateMoviePopUp’ object has no attribute ‘lineedit_path’
File “…\vtk_widgets\dialogs.py”, line 248, in browse
self.ui.lineedit_path.text())
I searched it. 248 lines of code is this line
“ self.ui.lineedit_path.text())”
Here are a few lines of his code
def browse(self):
filename = QtWidgets.QFileDialog.getExistingDirectory(
self,
“Save screenshot”,
if isinstance(filename, (tuple, list)):
filename = filename[0]
if not filename:
return
self.ui.lineedit_path.setText(filename)
I just installed the latest version of the software, the code has not moved, the current problem do not know how to get the result, looking forward to your help
