Mfix-24.4 build fails
I have not been able to compile even the simple tutorials with MFIX-24.4 either using Anaconda or even using miniforge (that you suggest downloading for Windows).
build_fail.txt (153.2 KB)
[ 17%] Building Fortran object model/CMakeFiles/mfixcore.dir/ambm_mod.f.obj
cd /d C:\Users\ebreard\Documents\MFIX-24\fluid_bed_tfm_2d-test-24-4\build\model && C:\Users\ebreard\AppData\Local\miniforge3\envs\mfix-24.4\Library\mingw-w64\bin\gfortran.exe -DBURCAT_THR="C:/Users/ebreard/AppData/Local/miniforge3/envs/mfix-24.4/share/mfix/src/model/thermochemical/BURCAT.THR" -DMFIX_VERSION="24.4" -DMINGW -DPYMFIX @CMakeFiles/mfixcore.dir/includes_Fortran.rsp -O2 -g -DNDEBUG -Jmod -ffree-form -cpp -Werror -ffpe-trap=invalid,zero,overflow -ffpe-summary=none -fconvert=big-endian -ffree-li
ne-length-0 -c C:\Users\ebreard\AppData\Local\miniforge3\envs\mfix-24.4\share\mfix\src\model\ambm_mod.f -o CMakeFiles\mfixcore.dir\ambm_mod.f.obj
[ 18%] Building Fortran object model/CMakeFiles/mfixcore.dir/chischeme_mod.f.obj
cd /d C:\Users\ebreard\Documents\MFIX-24\fluid_bed_tfm_2d-test-24-4\build\model && C:\Users\ebreard\AppData\Local\miniforge3\envs\mfix-24.4\Library\mingw-w64\bin\gfortran.exe -DBURCAT_THR="C:/Users/ebreard/AppData/Local/miniforge3/envs/mfix-24.4/share/mfix/src/model/thermochemical/BURCAT.THR" -DMFIX_VERSION="24.4" -DMINGW -DPYMFIX @CMakeFiles/mfixcore.dir/includes_Fortran.rsp -O2 -g -DNDEBUG -Jmod -ffree-form -cpp -Werror -ffpe-trap=invalid,zero,overflow -ffpe-summary=none -fconvert=big-endian -ffree-line-length-0 -c C:\Users\ebreard\AppData\Local\miniforge3\envs\mfix-24.4\share\mfix\src\model\chischeme_mod.f -o CMakeFiles\mfixcore.dir\chischeme_mod.f.obj
[ 18%] Building Fortran object model/CMakeFiles/mfixcore.dir/dmp_modules/gridmap_mod.f.obj
cd /d C:\Users\ebreard\Documents\MFIX-24\fluid_bed_tfm_2d-test-24-4\build\model && C:\Users\ebreard\AppData\Local\miniforge3\envs\mfix-24.4\Library\mingw-w64\bin\gfortran.exe -DBURCAT_THR="C:/Users/ebreard/AppData/Local/miniforge3/envs/mfix-24.4/share/mfix/src/model/thermochemical/BURCAT.THR" -DMFIX_VERSION="24.4" -DMINGW -DPYMFIX @CMakeFiles/mfixcore.dir/includes_Fortran.rsp -O2 -g -DNDEBUG -Jmod -ffree-form -cpp -Werror -ffpe-trap=invalid,zero,overflow -ffpe-summary=none -fconvert=big-endian -ffree-line-length-0 -c C:\Users\ebreard\AppData\Local\miniforge3\envs\mfix-24.4\share\mfix\src\model\dmp_modules\gridmap_mod.f -o CMakeFiles\mfixcore.dir\dmp_modules\gridmap_mod.f.obj
C:\Users\ebreard\AppData\Local\Temp\ccUO0eGp.s: Assembler messages:
C:\Users\ebreard\AppData\Local\Temp\ccUO0eGp.s:203: Error: invalid register for .seh_savexmm
model\CMakeFiles\mfixcore.dir\build.make:74: recipe for target ‘model/CMakeFiles/mfixcore.dir/DGTSV.f.obj’ failed
mingw32-make.exe[2]: *** [model/CMakeFiles/mfixcore.dir/DGTSV.f.obj] Error 1
mingw32-make.exe[2]: *** Waiting for unfinished jobs…
mingw32-make.exe[2]: Leaving directory ‘C:/Users/ebreard/Documents/MFIX-24/fluid_bed_tfm_2d-test-24-4/build’
CMakeFiles\Makefile2:152: recipe for target ‘model/CMakeFiles/mfixcore.dir/all’ failed
mingw32-make.exe[1]: Leaving directory ‘C:/Users/ebreard/Documents/MFIX-24/fluid_bed_tfm_2d-test-24-4/build’
mingw32-make.exe[1]: *** [model/CMakeFiles/mfixcore.dir/all] Error 2
Makefile:134: recipe for target ‘all’ failed
Would you happen to have a suggestion for me to proceed?
Please see MFIX 24.1.1 compilation failure "Invalid register for .seh_savexmm" - #5 by cgw
Ideed, fixed it with your suggestion:
C:\> mamba activate mfix-24.4
(mfix-24.1.1) C:\> cd %CONDA_PREFIX%\share\mfix\src\model
(mfix-24.1.1) C:\> notepad CMakeLists.txt
Find the section (line 620) that reads
set_source_files_properties(DGTSV.f PROPERTIES
  COMPILE_OPTIONS "${FFLAGS};-O3;-ggdb;${MARCH}")
and change that to
  COMPILE_OPTIONS "${FFLAGS};-O3;-ggdb")
For what concerns version 25.3, the issue was solved by changing the line 301
COMPILE_OPTIONS “${FFLAGS};-O3;-ggdb;${MARCH}”)
to
COMPILE_OPTIONS “${FFLAGS};-O3;-ggdb”)
